twinmax and Honda
(This archived section can be viewed by all, but modified only by Doug and moderators.)
This reference section highlights some key aftermarket accessories or installation walkthroughs that people have found useful.
gel9001
twinmax and Honda
Postby gel9001 » Sat May 28, 2005 9:25 pm
Pardon the off topic question. A buddy of mine has a Honda ST1300 and he bought a twinmax to synch his throttle bodies. Unfortunately he doesn't know how to use it and has asked for my help. I own one and use it on my R, but don't know how to use on non beemer bike.
Can someone point me in the direction to find instructions on how to use on this type of bike?
thanks,
Gene
Postby boxermania » Sat May 28, 2005 11:23 pm
Gene....you have an aversion for trouble.....always asking for it.....but kidding aside, I don't kmow much about the ST1300 other than is a 4 cyl.
So either the TB's are syamesed and you use the Twin-Max as you would on the BMW or if not I guess the you would sync the two cyl on one side first, then move to the other side and then compare one TB from one side to the other on the other side.......Hey, I don't know!!!!!
Call TwinMax...... :roll: :roll:
gel9001
thanks Al
Postby gel9001 » Sun May 29, 2005 9:06 am
Its a V4 so maybe only 2 throttle bodies. What you say makes alot of sense.
Oye, why not put the Cuban flag as part of your id? Where is that other flag from? And what part of Cuba are you from?
Gene
pbenoit
Postby pbenoit » Tue May 31, 2005 4:41 pm
Had a 4 cyl Kaw Concours and you synch'd the two left carbs first, the two right carbs next and than the two middle carbs to synch both sets (the carb to the #3 cyl was the base carb according to Kaw). I would assume that on the ST you would synch both throttle bodies on one side of the V, than synch the throttle bodies on the other side next, and than one throttle body from each side of the V (however, I don't know which one Honda uses as the base throttle body). Hope this helps.......
Peter Benoit
'98 R1100R
'04 R1150R (Replaced with 07 F650GS)
'05 R1200GS
darthrider
Postby darthrider » Tue May 31, 2005 5:08 pm
My buddy's TwinMax has instructions for setting multi's.
Dave
#226
gel9001
thanks guys
Postby gel9001 » Tue May 31, 2005 5:20 pm
appreciate the help
Gene
Return to “Installations”
