Ignition reset procedure
(This archived section can be viewed by all, but modified only by Doug and moderators.)
This reference section discusses maintenence and service issues.
mxstone
Post by mxstone »
I searched a bit and came up empty screened. What is the procedure to reset the motronic after removing the CCP? I pulled the 5th fuse and then what? I remember something about blipping the thottle with the key on... :?: :?
MikeCam
Centurion Moderator!
Donating Member #: 100
You're There
Post by MikeCam »
With key on but not started, roll throttle to full open and release; repeat 2nd time. Key off. Let's the TPS sense the range of throttle motion and memorize it.
mxstone
Post by mxstone »
Thanks Mike
