I have a 1996 r1100r. When i went to change the transmission oil, i was/am unable to find the fill and drain plugs. i know that this sounds dumb yet the side of my bike does not match the pic in the haynes manual. I also looked underneath to no avail. thoughts on where they might be? thanks
Patrick
1964(?) Honda 50 (long gone)
1976 Honda 450 (gone too)
1995 Kawasaki Vulcan (reentry bike)
1996 r1100r aaah!
transmission oil change
Patrick,
According to my Clymer manual, the drain plug for your bike should be underneath the transmission case.
On the right side of the transmission case for the 1150R, there are two caps, one right above the other. The upper is the oil filler cap, the lower, the drain cap. If I read my manual correctly, on your bike there is only one, the oil filler cap. Look carefully below the transmission case and you should be able to see the drain cap.
EDIT>>>
Here is a photo to help illustrate. As you can see, on a 1150 R, there are actually 2 drain plugs. On your bike, there will be only one - the very bottom one. Hope this helps :
EDIT>>>
transmission drain plug
Thanks guys, much appreciated
Patrick
Patrick
