I'm not sure which barbacks you got. Were they the older model or the newer ones? You can tell by the fillet radii. Are they small hand sanded or nice full machined. If you got the older ones, let me know, and i'll get you a set of the newer/prettier onesjfslater98 wrote:Absolutely. Stay the course Johnny, I will be the first one in line for what you are making.johnnyjs1 wrote:Think any interest would be out there for R riders?
Parts/pieces you wish you had, but no one makes
Re: Parts/pieces you wish you had, but no one makes
09 Someting??
Lifer 607
09 Someting??
Lifer 607
- jfslater98
Actually, I got your "seat risers". Those cubes you machined? They're working great, did my first ride into work today. Even got some extra test time when I realized I forgot my work clothes and tried to ride home
PM me your address. I got another set I was using for my seat. They are shorter...I think 1/2"? Still gives you a more level seat than stock, but allows the tabs to seat onto the tank, hence less gap. I dont need em anymore and you are welcome to them, since i just got a new Mayer seatjfslater98 wrote:Actually, I got your "seat risers". Those cubes you machined? They're working great, did my first ride into work today. Even got some extra test time when I realized I forgot my work clothes and tried to ride home
Johnny
09 Someting??
Lifer 607
09 Someting??
Lifer 607
Johnny the seat clamshell is what I was thinking. I ride solo so no worry about GF. Can't wait to see the pics.
Michael
MG 78 LeMans
78 R100S
MG 78 LeMans
78 R100S
Yeah...I'm not sure how I'm gonna get the G/F to the Bash if I mount the bubble on the bikemcollect wrote:Johnny the seat clamshell is what I was thinking. I ride solo so no worry about GF. Can't wait to see the pics.
09 Someting??
Lifer 607
09 Someting??
Lifer 607
toolinalong
- Double Lifer
skid plate sounds good, also $50 aux light brackets might be popular.
A device for attaching the full size left side case in an aesthetically pleasing manner.
A cool new style of handlebar accessory mounts, something less bulky and more elegant then what is currently out there. Maybe an accessory shelf like the one made for the RT, but designed just for the R.
A better headlight is always at the top of my list (one with a better reflector/lens combination that focuses more of the light available from the bulb, a lighting fixture designer is needed to wrestle that one). Hmmm. I have an idea. I'll get back to you.
"none.nada.thank you."
This has been done. Just have to get Johnny to get er done.
@OU812
that looks
with a Capital C..
How does the 'can tip down to that angle?? nice and easily??
Fancy doing that if i can find a full size LH case.
Digga
that looks
Digga
Re:
Take a look at the rear seat storage unit in these photos: http://www.r1150r.org/board/viewtopic.php?f=3&t=13674johnnyjs1 wrote:Ok.....gimme some input on this. Mind you, its rough as i drew it up in MSPaint, but you get the idea. What about something that replaces the rear seat, and adds waterproof storage behind you. I would try to make it fit the lines of the bike as well. I used a Rockster pic as it was handy on my computer. Maybe made out of aluminum or fiberglass or something light that could be painted to match your bike. Don't be too hard on me, but your honesty is much appreciated![]()
I'd like one of those if it wouldn't require a 2nd mortgage.
Rick
2003 R1150R: Silver
Lifetime Member #585
2003 R1150R: Silver
There is a part called the "S" pipe or police S pipe. Also needed an extra clamp. The pipe turns the can down and extends it back a few inches also. Works with the stock can and also the Remus.(what I used)digga wrote:@OU812
that looks![]()
with a Capital C..
Digga
Cam tunnel covers with a sight glass insert. These can be machined from plastic and a round sight glass securred at a groove in the ID with a steel retaining ring. Cheap and a nice dress up for the boxer engine. The deluxe version could even have a LED incorporated for illumination of your cam sprockets...WOW just call me Mr. Farkle...Now if you want to get fancy, use alloy stock and anodize them in various colors..but the cost skyrockets, likely X3.
The plain plastic ones (no LED) could be made for about $10.00 each and sold for $39.95 each.
Modified boxer transmission input shaft with extra length at the splines to fully engage the clutch disk. You'll likely need a grinding attachement for the splines and tolerancing the shaft ODs. After the machining steps, heat treating will be required...possibly over your level...no insult intended here but, a transmission input shaft must be straight and critical ODs must be held to 0.0003 to 0.0005" and these tolerances must be held after hardening or heat treating so grinding is a must. The steel alloy is critical, as well. Metalurgists chime in here as well. I believe BMW charges about $250.00 for this piece. Many R models suffer from spline failure at the clutch/input shaft interface. A modified shaft would eliminate this weak design in the OE piece.
Modified cam (valve) timing. If you can profile grind, offering cam grinds with various profiles would sure be nice. There are few sources for aftermarket cams for the boxer engine. Surface finish as well as the steel materials would be critical. Heat treating is necessary for cam lobes....possibly carburizing or case hardening might be sufficient. You could spray up used cams and regrind the old cores to save money...this is done frequently.
How about a versatile rack system. I have fashioned My own but it's kind of crude. I want it flip forward or back to accommodate different loads. It also needs to stand up straight with a pad and it's a backrest. Would be cool if it could slide forward for driver only use. Don't look to closely, I am an electrician not a fabricator.
I am utilitarian, and always looking for a way to make My bike more useful.
Keep Your Stick On the Ice.
Listen to Me at kaxe.org
Very nice concept!! Slimmed and trimmed up a bit, that would look and work very nicely.
09 Someting??
Lifer 607
09 Someting??
Lifer 607
johnnyjs1 wrote:Very nice concept!! Slimmed and trimmed up a bit, that would look and work very nicely.
I have a vision, I just haven't been able to build it yet. When I do I'll post the results.
Coffeebean
WHERE can I purchase this attachment?OU812 wrote:This has been done. Just have to get Johnny to get er done.![]()
johnnyjs1 seems to be a bit overwhelmed these days and was wondering if anyone else was able to make one of these?? Is there a simple way to make these myself? help?
I am joining this a bit late, but my wish item is a passenger backrest that can be mounted if you have a givi toprack plate installed.
I have a topcase with backrest, but the backrest juts out far enough to eliminate part of the seat for the pillion. I have seen backrests from RCU, Pirates Lair, etc...but all require the OEM rack. So I would be using this without the topcase in place, but the permanently mounted Givi plate is installed in place of the OEM rack. Got that?
Oh, and the givi case rack mounted into the siderail holes with adapted hardware.
Maria
2004 Silver R1150R - The Fastest Color
Not sure if it's been mentioned already upthread, but someone in the US or Canada already makes one for the R1150GS - I'd "guesstimate" that the same part would fit the R-R. There was a link somewhere in one of the rive-shaft failure threads, or search AdvRider.com for it.def38 wrote:Modified boxer transmission input shaft with extra length at the splines to fully engage the clutch disk. You'll likely need a grinding attachement for the splines and tolerancing the shaft ODs. After the machining steps, heat treating will be required...possibly over your level...no insult intended here but, a transmission input shaft must be straight and critical ODs must be held to 0.0003 to 0.0005" and these tolerances must be held after hardening or heat treating so grinding is a must. The steel alloy is critical, as well. Metalurgists chime in here as well. I believe BMW charges about $250.00 for this piece. Many R models suffer from spline failure at the clutch/input shaft interface. A modified shaft would eliminate this weak design in the OE piece.
