question about bolt
sstein
Donating Member #: 25
question about bolt
Postby sstein » Sun Sep 08, 2019 7:27 pm
I am putting my stock exhaust back on. Lost the original bolt to fasten it to the bracket
It is a HEXAGON SCREW WITH FLANGE - M8X40-8.8-ZNS3
I get that this is a metric 8 mm diameter bolt, 40 mm long. What is the 8.8 and the ZNS3?
Is this something I can get at like Home Depot or a local hardware place? Or more specific?
2002 R1150R
- my brother-in-law's brother
Re: question about bolt
Postby towerworker » Sun Sep 08, 2019 7:57 pm
Not sure what the ZNS3 is but the 8.8 designates a high strength bolt. Equivalent to a Grade 8 in a SAE bolt. Also probably a fine thread bolt. Pitch of 1.25 or 1.0. A pitch of 1.5 is considered a coarse thread. And yes a good hardware or building supply should have it.
The Older I Get, The Less I know. (in honor of MikeCam)
sstein
Postby sstein » Mon Sep 09, 2019 4:04 am
Great thanks.
2002 R1150R
Mr.Frequent
Postby Mr.Frequent » Tue Sep 10, 2019 11:47 pm
ZN just designates a zinc coating ,but I think Motorrad switched to a different plating method now.
8.8 is the strength ; wish tje had hashmarks on them like SAE does.
sstein
Postby sstein » Thu Sep 12, 2019 4:54 am
Thanks. I ended finding the right bolt at the hardware store. It is zinc coated but I don't know what the strength is. seems to work fine.
2002 R1150R
Mr.Frequent
Postby Mr.Frequent » Thu Sep 12, 2019 10:28 pm
I can't imagine that even a bit softer bolt would hurt since it's just the exhaust.
Return to “R 1 1 5 0 R”
Users browsing this forum: Bing [Bot] and 23 guests
