I read before about the cutting out on some R1105's but mine when I crank it out to higher RPM really cuts out - almost seems like it is starving for fuel or air or both - any suggestions - recommendations? I have 9700 miles on it and in lower RPM's runs fine but when I put it into "lets move" mode, and go into the upper RPM range it really gets bad - Air filter is new, Battery is new (Odyssey), oil been changed/ On the bottom end no issues at all but when I throttle back I get some blow-backs here and there so it seems to get enough gas there but on high it is all over the place.
Any suggestions welcome
