Front fender replacement
What other model front fenders will fit on a '04 R1150R? I'm not crazy about the beak and the oil coolers get plenty of air flow. It seems like the beak kicks more wind onto one's chest when riding then a typical fender does. I thought I read a thread that mentioned the RS fender would fit on the R's?
Brett
Re: Front fender replacement
http://www.whaccessories.com/BMWAccessories.htm
This website has a pretty good looking front fender.
Bryan
2010 R1200R
2010 R1200R
I changed my beak out with another beak of sorts - that from a R1150RS with the added fork leg pieces...
It is a direct bolt on. The inner portion or mudguard is that of a K1200LT.
- AirForceDirt
Are those carbon fibre fork sliders? Or is that all part of the front fender?
Those are carbon fiber fork leg covers/protectors that a friend made for me.
I had my fork legs powder coated black then added the covers/protectors...
Available here: http://www.parecomposites.com/
So a rockster or R1150S front fender won't work with the R1150R forks is the impression I'm getting??? Is there anything else across the model line with a fender similar to the S or Rockster that will fit on the R?
Brett
- AirForceDirt
Right. The r11s and rockster fenders will not fit on an r1150r, but are nearly interchangeable with each other (1100s fender fits on a rockster mostly, with a little play, i believe).duegi wrote:So a rockster or R1150S front fender won't work with the R1150R forks is the impression I'm getting??? Is there anything else across the model line with a fender similar to the S or Rockster that will fit on the R?
The front fender from the K12RS will also bolt right on...Is there anything else across the model line with a fender similar to the S or Rockster that will fit on the R?
There should be some images on this site as I recall seeing them.
I changed mine in 2003 or so. I think its a K12000S (or RS?) Picture are lo-res - sorry.
<<Edit>>Took a better pic.
Most excellent, I've got one coming as we exchange info. It's off an '04 K12RS and just happens to match what's on your R bike, thanks for the pics as you confirm what I was expecting the bike to look like with the alternate fender. What did you use for the rear 1/2? The existing R fender that was on the moto?
Brett
Yes - the rear half is stock. You are left with a cast cross bracket when you take the beak off. As you can see in the upper photo, I used to have a little plate attached to it (expressing my incredibly wise and insightful political views) That has since been deleted and only the cast bracket remains. (bottom pic)
So I now have a Black Fender from a 2004 K1200RS and it will fit, what I lack is the correct bolts to install it. does anyone know what I need? The existing beak bolts are of no help.
Thanks in Advance
Thanks in Advance
I'm fairly sure if you take one of the beak mounting bolts they should fit into the mounting points for the K bike fender. I don't remember the lengths off the top of my head but you'd find what you need at any hardware store. I'd recommend something out of stainless steel. Perhaps a washer under the head of the bolt to spread the load on the fender mounting point. Maybe some blue loc-tite to ease your mind about the bolts coming loose.
Brett
If you're screwing stainless into aluminum or vice-versa I'd use some anti-sieze compound to prevent galvanic corrosion. Don't know if it is entirely necessary but it's always better to be safe than sorry when joining dissimilar metals.duegi wrote:I'm fairly sure if you take one of the beak mounting bolts they should fit into the mounting points for the K bike fender. I don't remember the lengths off the top of my head but you'd find what you need at any hardware store. I'd recommend something out of stainless steel. Perhaps a washer under the head of the bolt to spread the load on the fender mounting point. Maybe some blue loc-tite to ease your mind about the bolts coming loose.
I like the K12RS replacement fender as well. The beak matches the lines better but still not my favorite.
2017 Husqvarna 701
2007 Husqvarna TE250
2004 BMW Rockster
2004 BMW Rockster
What year? Is it a direct bolt-on as well? I like the extended rear fender. Think it might help control water a little better. Have you noticed that it helps or do you just like the look?rivi7777 wrote:The inner portion or mudguard is that of a K1200LT.
2017 Husqvarna 701
2004 BMW Rockster
2004 BMW Rockster
Just done the swap with a k1200rs mudguard. The beak's bolts are quite long and go through some mounts that are a cast part of the front forks. Did you hacksaw those off?
