Fuel smell after removing canister
I got tired of looking at the thing hanging off the back of the subframe and decided to remove it. I ended up capping the vacuum lines at the throttle bodies and tying the two lines from the fuel tank together. I do now notice a fuel smell at times and understand that many do not post-removal. I wonder if perhaps I have missed something here in the process. How does the tank vent now that I have tied the lines together? Bike runs very well. May have a drop in mpg unless I am imagining this. Any advice appreciated. Thanks
Johnny
04 R1150R GONE
10 R1200R GONE
04 R1150R GONE
10 R1200R GONE
Re: Fuel smell after removing canister
The reason for having the canister was to filter the gas smell coming out of the vent, so I'd say that's the price you pay.
Go Sabres!
Methinks I may have erred by tying the ends of the two vent lines together effectively leaving only the tank cap vent. If I am re-reading the instructions correctly, both of the lines leaving the tank should be open to atmosphere and exit near the battery vent line. So, I need to remedy this, no? As far as the gas smell, a slight odor is not an issue as I have a shop full of unfiltered fuel tanks on various pieces of equipment. I do not keep any fueled equipment or fuel in an attached garage (bad idea, I think, yet convenient).
Johnny
04 R1150R GONE
10 R1200R GONE
04 R1150R GONE
10 R1200R GONE
You should let both of those vent lines drain since one of them vents in-tank pressure and the other drains water that collects around the filler neck. Connecting them together will put that water in your tank.
Plumbing has been corrected. Fuel smell has disappeared. Thanks
Johnny
04 R1150R GONE
10 R1200R GONE
04 R1150R GONE
10 R1200R GONE
