So I check the local Beemer shop, prices have gone through the roof, I hit the interweb and find “Euro MotoElectrics” (http://www.euromotoelectrics.com) with good prices and give them a call. I don’t know if John is the owner but he sure took care of biz as if he was. John and I chat for a bit about BMW changing vendors for the primary stick coils and that they sell the ones BMW use to get. With one thing and another the talk leads to heat being the killer of the stick coils and the possibility of not putting the coils back into the top end of the cylinder and hiding them somewhere away from heat and out of the elements. We worked through a few scenarios. Figured under the seat and mounted to the frame would be the way to go. John came up with sparkplug wires like what would go on a non twin spark R1150R bike and the coils I needed
Now what all do I need?
1. Sparkplug wires long enough to reach under the seat after being connected to the sparkplugs buried in the cylender heads at 50 buks a set.
2. The correct speck stick coils for my bike at 120 buks a peice.
So here's what I ended up with.
Sparkplug Wires
Coils
You will need to pull off the boot off of coil end of the new wires. I know 50 buks out the window, right? Trust me, I'll respect you in the morning.....
Remember those old sparkplugs you didn't throwaway sitting in the tray of your tool box? Go get two of them and hammer the porcelain off, twist the rod off and sharpen a panicle tip on the rod.
Now take the new 50 buk sparkplug wires you ruined. You know your Mom told you not to trust little Johnny that he was a bad boy and sooner or later he was going to cost you some grief… Well I’m not little Johnny
Here’s what you do, take the rod you sharpened and push it into the end of the wire.
So you have this. Take this end and plug it into the new stick coil.
Here's what it all should look like, all ready for plug and play.
Routing and mounting is a snap.
Here’s the stick coil mounted to the frame.
Make sure that the ground lead of the existing wiring is connected to some unpainted steel.
Here I took off the rear gas tank mounting bracket, you also need to remove the mounting plate that the bracket bolts into. Don’t connect the ground between the tank bracket and it’s mounting plate, that plate is plastic and will not ground to the bike. Make your ground connection between the frame and the mounting plate.
Routing from the frame to the cylinder head.
Over the Intake
Under the TB
Finishing up
Put the cover over the sparkplug and go for a ride.
Remember what your Mom told you about little Johnny! If he told you to jump off a cliff, would you do it? Well I'm not telling you to do this Mod, I'm just showing your waht I did. I don't guaranty that this will last or save you dollars down the road or leave you stranded somewhere you realy don't want to be.
So I leave you to your own devises.
BTW - Being the bike was at 37k miles "Euro MotoElectrics" had air, oil filters, fuel filter and screen. Call John (303.526.0901) he's a good guy, let him know you saw my post he may just start giving us a brake on prices,
See ya down the road.
