Final Drive Additive?
Postby towerworker » Wed Apr 11, 2018 5:29 pm
My R has near 90K. I've been running Guard Dog Moly in the final drive since probably 20K. Of course they shuttered their doors in 2016. Wondering if any of you have run that or a similar product in your FD. Since they're not around I'm looking for a replacement. Any suggestions?
The Older I Get, The Less I know. (in honor of MikeCam)
RadicalR1150R
Donating Member #: 960
Re: Final Drive Additive?
Postby RadicalR1150R » Wed Apr 11, 2018 7:10 pm
Hey Wayne. Check your e mail. i sent a photo of Lubro Moly, Anti friction for gears.. I've used in the past..
I think it was purchased at BB..
Steve.
Buckster
Donating Member #: 543
Postby Buckster » Thu Apr 12, 2018 4:35 am
http://www.mgcycle.com/index.php?main_p ... ts_id=4541
I bought it last year from here. Looks like you can still get it!
Buckster '03R
#543
Postby towerworker » Thu Apr 12, 2018 7:05 am
Hey Steve...never got your email. ...is this what you used?
Buckster...Thanks!
Postby towerworker » Thu Apr 12, 2018 7:17 am
Ordered some! That's just what I ran out of. I didn't think there was any still around.
Many thanks......
EasyBee
Donating Member #: 61
Postby EasyBee » Thu Apr 12, 2018 3:26 pm
Better not give your email away in a public forum. You get a lot of spam, and fishing mails.
RadicalR1150R
Postby RadicalR1150R » Thu Apr 12, 2018 3:51 pm
Wayne. yep that's what I used, only leaving out the last y....lol..
Steve
Postby towerworker » Thu Apr 12, 2018 8:18 pm
EasyBee wrote:Better not give your email away in a public forum. You get a lot of spam, and fishing mails.
Good point. My email provider is pretty good at weeding the stuff out but you never know. I fixed it.
Hyja1
Postby Hyja1 » Sat Apr 14, 2018 6:07 am
Does anyone use moly in their transmissions? My trans has always been a bit clunky and was wondering if adding moly would smooth it out...
Holland Ja, San Francisco
‘02 R1150R black
kirby
Donating Member #: 3
Postby kirby » Sat Apr 14, 2018 8:13 am
In a word...NO.
Getrag "clunking in everything from motos to giant trucks for 100years" inherent to the brand. Only surpassed by Harley clunkers!
About the only thing that would "quiet" a getrag is saw dust or bananas.
Getrags are very tough.
All jokes aside, moly will not make any difference,(noise wise), its actually not good for some bearings as its too slippery. Use too much moly on "high speed" roller bearings and it can cause them to "skid" due to low friction which can be not so pretty good. (just so you know). So what is high speed? Well the rear drive main bearing is a tapered roller, it might be considered a high speed? (I would).
That's probably why BMW does not specify a moly additive.
Having said that...allot of folks do it anyway and..have no trouble??? But many figure that the more slippery the better.?! (Much depends on how much moly you put in)
I have never run an additive in either the transmission or rear drive....250K miles and counting. (dino)
However its a personal choice I guess. Many have used w/o undue effects.???
The SAE in me says no.
DAM650
Postby DAM650 » Sun May 06, 2018 5:17 pm
kirby wrote:In a word...NO.
i watched chris harris put the same synthetic lube in the trans and the rear
75/130 i think. something like that
then i read AFTER MY REAR BEARING FAILED, that you should use 75 90 in the diff. i will always wonder if using the trans weight lube in the diff had anything to do with the failure. likely not, but the thought will always be there.
any way. what is your take, and what have you been using.
btw. got about 4 more mpg since replacing the rear bearing, so that says it's been on the way out for some time. likely since i have owned the bike
2002F650GS ABS Black Betty 89K
2002R1150R ABS Misty Blue 48K
Return to “R1150R”
Users browsing this forum: Bing [Bot] and 14 guests
