I was replacing the rear brake pads with EBC HH pads. When I pulled the stock pads this Silver metal Tab fell out.
Is this where it goes before installing the pads?
https://photos.app.goo.gl/4dPT4MBUpWo6ZaWY7
Help with Caliper Part
1974 Kawi H-1 500
1975 Norton 850
2002 BMW R1150R
2008 Suzuki Bandit 1250
2013 BMW GS 650 Sertao
1975 Norton 850
2002 BMW R1150R
Re: Help with Caliper Part
Yes. The arrow (triangle) should point toward the front when the caliper is installed.
Thank you! I assumed it is a spring plate to keep the pads from rattling providing pressure against the keeper pin.
I pushed the pistons out a bit, sprayed everything off with brake cleaner, pushed them back in and installed the EBC's.
Experiencing some heat from brake drag and wanted to be sure it wasn't the spring plate causing it.
Will need to work on this.....
1974 Kawi H-1 500
1975 Norton 850
2002 BMW R1150R
1975 Norton 850
2002 BMW R1150R
