Flat Towing-
omoore3
Flat Towing-
Postby omoore3 » Tue Oct 16, 2018 12:36 pm
Will towing with one of those brackets which holds the front wheel off the ground damage the trans?
Oliver
2004 R1150r
1973 Yamaha RD 350
1963 Bultaco Lobito
Oliver
1994 BMW R1150r
1974 Yamaha RD 350
1963 Bultaco Sherpa
Sunbeemer
Donating Member #: 593
Re: Flat Towing-
Postby Sunbeemer » Tue Oct 23, 2018 6:40 pm
Not the transmission, but I read there is a press-fit (Morse-taper?) joint in the drive shaft that can come apart, so towing with the rear wheel on the ground is not advised. Can anyone corroborate this? This might have only applied to Airheads...
kirby
Donating Member #: 3
Re: Flat Towing-
Postby kirby » Tue Oct 23, 2018 9:21 pm
The u's are staked in their yokes and the two halves just slide together on splines. Really can't come apart when installed.
Don't think it would hurt anything, but having said that I never really liked those tow methods. Not sure how the air head works as I never had mine apart(r90 and r80gs) Never seen one towed that way as I recall.
Return to “R115OR”
Users browsing this forum: Bing [Bot], Majestic-12 [Bot] and 28 guests
