Front Shock Cover
Front Shock Cover
Just wondering if anyone has put a Neoprene wrap/cover on their front Shock?
Seems like a good idea to keep the crud off the shaft. I use them on my mountain bike shock and forks. Also on the Sertao rear Shock with no issues. I suppose heat build up may be a concern. The 2002 has such low miles I’d like do this sooner than later.
Thanks !
Thanks !
1974 Kawi H-1 500
1975 Norton 850
2002 BMW R1150R
2008 Suzuki Bandit 1250
2013 BMW GS 650 Sertao
1975 Norton 850
2002 BMW R1150R
Re: Front Shock Cover
No! But good idea!
I looked into this a while ago and found some gators that were split but didn't think they'd fit. After thousands of road miles I haven't noticed much pitting on the shafts, probably since they are at the top of the forks and less likely to be struck by stones, etc.
Well most Neoprene cover are longer than the 11 inch length/2 1/2" Dia. required.
I did find this HD Nylon cover on Amazon for under $10. Hoping the print is only on one side
https://www.amazon.com/dp/B00DT8BQB2/re ... B00F9XNBKO
Like the fork tubes it would be nice to keep the grime and Bugs off the shaft.
I will update on fitment when I get it. No test rides on the Tundra....yet.
1974 Kawi H-1 500
1975 Norton 850
2002 BMW R1150R
1975 Norton 850
2002 BMW R1150R
I received the front Shock cover. Easy 5 minute install. there good sized breather holes on the back side. We shall see how it holds up.
Also got the used 2004 SS braided brake lines and Hella Horn upgrade done....since they are in the pictures.
https://photos.google.com/search/_tra_/ ... ZHSGgfKhMP
https://photos.google.com/search/_tra_/ ... RlPYlInzQA
1974 Kawi H-1 500
1975 Norton 850
2002 BMW R1150R
1975 Norton 850
2002 BMW R1150R
Sounds interesting, good project.
Your Google photos links didn't work for me...
I have had Ohlins on my rockster since new and they have been rebuilt about 7 or 8 times and I have never had to replace a shaft on either.
No unusual maintence has ever been applied. I like to be able to keep an eye on the shaft for any signs of leaking.
The links to google photos do not work. "Error 404, URL link not found on this server".
@Kirby
I suppose the covers are for the 2 front legs https://www.realoem.com/bmw/enUS/showpa ... Id=31_0337 and not the front spring/shock https://www.realoem.com/bmw/enUS/showpa ... Id=31_0532.
@Kirby
Yes,
My point is that he wants these covers for protection of the shock shafts. They really don't need protection in my experience. So if you install covers then you have collected more "crud" all over the covers?!
Ugh!
Ugh!
Shocks (Front) and Forks get bugs, road grime etc. on the shafts/tubes. This accelerates wear on the seals in place to keep the internals and fluid from getting contaminated. As stated, I use and have used shock covers and fork protectors with no issues. If you don't see the need, by all means don't apply them.kirby wrote:I have had Ohlins on my rockster since new and they have been rebuilt about 7 or 8 times and I have never had to replace a shaft on either.
1974 Kawi H-1 500
1975 Norton 850
2002 BMW R1150R
1975 Norton 850
2002 BMW R1150R
Yes quite right, by all means.
And no I don't see the need, thought I made that clear.
Try these links for photos.
https://photos.app.goo.gl/rPYYY7CY98eLkn4F9
https://photos.app.goo.gl/PVsnsLZxF7ZUFRMb8
Thanks!
Thanks!
1974 Kawi H-1 500
1975 Norton 850
2002 BMW R1150R
1975 Norton 850
2002 BMW R1150R
Never had an issue with the shafts, or seals on the shocks on the R1150R(even riding it on dirt and gravel roads
Jeff (lifer #289)
'17 F800GSA
'04 R1150R
'17 F800GSA
'04 R1150R
