starter/solenoid issue???
When i try to start 1150r it sounds like a small hammer tapping near starter. Sounds like a low battery, but battery tender is green. whats next?
thanx kb
thanx kb
Re: starter/solenoid issue???
Cant go by what the battery tender says
It just knows it aplied the proper voltage to the battery and then shut off
Put a volt meter on the stater battery positve and the Ground and see what voltage you have when cranking
82 R65
04 R1150R
04 R1150R
Ditto that.Mrclubike wrote:Cant go by what the battery tender says
Starter solenoid clicking - battery, insufficient juice.
Agree with the guys. New battery in your future. Strongly recommend Odyssey PC680.
https://www.amazon.com/ODYSSEY-PC680-Od ... 263&sr=8-2
X2 on the Battery.
IBA#7147
IBA#7147
I second thattowerworker wrote:Agree with the guys. New battery in your future. Strongly recommend Odyssey PC680.
I have 2 of them
Yes they cost more but My first one is still going strong after 5 years
82 R65
04 R1150R
04 R1150R
What do you remove to keep the bike from starting when you are testing as it is cranking over?
^ I don't know if this is the proper way or if there's a better choice, but the bike won't start with the side stand down...right?
You could pull the plug wires.....
Holland Ja, San Francisco
‘02 R1150R black
‘02 R1150R black
When you're testing what exactly? You can remove spark plugs (ground them to frame to allow spark discharge). You can disable fueling by disconnecting injector electrical connector.skylarmav1 wrote:What do you remove to keep the bike from starting when you are testing as it is cranking over?
