Tyre (tire) pressures for Metzeler Z6s?
MartinW
Postby MartinW » Fri Mar 09, 2007 11:01 am
Any advice on pressures for these tyres - with one 160lb rider and speeds up to 90mph approx (on the Autobahn of course!)
My handbook gives a generic 32 front 36.? rear but I notice that oilhead.com's CheatSheet shows 38/40.
Postby riceburner » Fri Mar 09, 2007 11:35 am
no idea what the weights mean cos I still work in stone - but I run 36/42 which I believe is the Tyre manufacturers recommended pressures.
TonyO
Donating Member #: 517
Postby TonyO » Fri Mar 09, 2007 12:32 pm
RIDE mag tyre guide states 2.5bar front 2.9 bar rear which in real money is 36/42 psi for R1150R 01 - with 5.5" rear rim
Tony
Member #517
R1200GS (09) Metallic Grey
N.Yorks
England
MartinW
Postby MartinW » Fri Mar 09, 2007 12:47 pm
36/42 sounds good to me.
(I was catering for the American market quoting my weight in pounds!!)
Thanks to both for the info.
scottdelamancha
Postby scottdelamancha » Fri Mar 09, 2007 1:02 pm
A stone is approximately 14 pounds?
MartinW
Postby MartinW » Fri Mar 09, 2007 1:52 pm
A stone is exactly 14 pounds. Just a quaint little measurement that we use on this side of the pond and after all 11st 6lbs sounds much lighter than 160lbs!
sjbmw
Moderator
Donating Member #: 263
Postby sjbmw » Fri Mar 09, 2007 2:40 pm
I weigh a lot of stones.
scottdelamancha
Postby scottdelamancha » Fri Mar 09, 2007 3:29 pm
I learned about stones when in Scotland. I dont want to consider my total in stones! :oops:
Croc
Stones
Postby Croc » Fri Mar 09, 2007 3:53 pm
I think I am going to quote my age in Stones..... \:D/
Wind in your hair......
Silver '03 ABS (Twin Spark)
scottdelamancha
Postby scottdelamancha » Fri Mar 09, 2007 4:26 pm
That took me a minute! Can stones be used as a unit of measure for any ole thing? Sweet! :evil:
Croc
stones
Postby Croc » Sat Mar 10, 2007 7:59 am
Yeah, why not? My age would be 3 stone 7, then! Sounds way better than 50 something! :P
Croc
Darius
Donating Member #: 597
Postby Darius » Sat Mar 10, 2007 2:44 pm
I weigh 160 lbs. Secondwind BMW set the pressure at 38 front 40 rear when they installed my z6s.
gregor
Postby gregor » Sat Mar 10, 2007 4:08 pm
Those pressures seem pretty high.
My bike wears out the centre tread fast enough already!
I'm 15 stones and use 36psi front and 38psi rear , which is the recommended BMW two up pressure.
I know some tyre manufacturers seem to recommend a universal higher pressure.
dwayne
Postby dwayne » Sat Mar 10, 2007 8:53 pm
sjbmw wrote:I weigh a lot of stones.
:lol:
The Velvet Monkey
Postby The Velvet Monkey » Sun Mar 11, 2007 5:06 pm
I've been running 38/42 on my Z6s at the recommendation of my dealer. I'm a slim 275lbs (2 3/4 boulders--not stones).
I've got what I think is an amazing 10k on the rear and it still looks good.
Metzlers wear like iron and are worth every cent.
2004 50R a.k.a. "Hiedi"
No!!! Bad monkey!!
MIXR
Postby MIXR » Sun Mar 11, 2007 6:43 pm
I seem to have graduated from stones to rocks in the past few years. I'm now getting back down to stones! Rocks are too heavy to carry around.
16 ounces in a pound - 14 pounds in a stone.
2.2 pounds in a kilogram.
Then there is the US measure and the imperial measure to add more confusion. A US gallon is a different quantity to an imperial gallon!
And - 36/42 for me, loaded, unloaded, fast, slow, pillion, pillionless.
yjleesvrr
Postby yjleesvrr » Mon Mar 12, 2007 9:10 am
I pump up my tires to 36 psi front, 40 back. I check pressure periodically until each tire loses about 4 psi and add air.
Member #93, June 2002
'14 BMW R1200RT "Wethead"
'77 BMW R100/7 "Airhead"
NK ED
Postby NK ED » Mon Mar 12, 2007 8:48 pm
The Velvet Monkey wrote:I've been running 38/42 on my Z6s at the recommendation of my dealer. I'm a slim 275lbs (2 3/4 boulders--not stones).
Those Florida roads must be awfully smooooooooth to get 10K on a rear Z6
yjleesvrr
Postby yjleesvrr » Tue Mar 13, 2007 9:03 am
I got 14k out of my last rear Z6 up and down the East Coast.
Postby riceburner » Tue Mar 13, 2007 1:45 pm
gregor wrote:Those pressures seem pretty high.
oddly enough - having a LOW pressure will allow the tyre to deform more, and make it heat up - thus causing undue wear.
so having the pressure lower is going to square the tyre off quicker.... ;)
Return to “R 1 1 5 0 R”
Users browsing this forum: Bing [Bot] and 48 guests
