Misfire/rough running
Eagle6
Postby Eagle6 » Thu Aug 09, 2018 12:20 pm
I've had this issue 3 or 4 times since I bought the bike at the beginning of July.
It happens when starting from cold.
It fires up immediately but goes into a chugging mode as if running on 1 cylinder. The rev counter bounces between 1K and 3K. Blipping the throttle will allow you to pull away but throttle control is almost like an on/off switch. After a few miles it seems to settle down and runs very smoothly.
I've tried switching the ignition on and off without any change and I've had the main coil packs out and plugs with nothing to show anything unusual.
I'll be pleased to hear if anyone has any ideas what may be the problem.
The mileage is only 3,300.
2017 R1200R Exclusive rusted away so back with the real thing 2012 R1200R TC
mogu83
Re: Misfire/rough running
Postby mogu83 » Fri Aug 10, 2018 8:43 am
Mileage 3,300 ???? Is it new or has it been sitting somewhere.?
2011 Sportster
Eagle6
Postby Eagle6 » Fri Aug 10, 2018 9:04 am
mogu83 wrote:Mileage 3,300 ???? Is it new or has it been sitting somewhere.?
Bought it early July with 2,661 miles.
mogu83
Postby mogu83 » Fri Aug 10, 2018 12:08 pm
Eagle6 wrote:Bought it early July with 2,661 miles.
Interesting but Is it new or has it been sitting somewhere??
2011 Sportster
Eagle6
Postby Eagle6 » Fri Aug 10, 2018 12:41 pm
It's a 2012 model that had a previous owner. He rode the 2,661 miles.
It's obviously not been ridden regularly as can be seen by mileage.
mogu83
Postby mogu83 » Fri Aug 10, 2018 2:35 pm
Seeing as it sat a while maybe (just maybe) this could be relevant. Posted by Don Eilenberger a while back it's about cleaning the grease in the stepper motor.
http://www.r1150r.org/board/viewtopic.php?f=20&t=27819&p=231101&hilit=stepper#p231101
2011 Sportster
Postby deilenberger » Sat Aug 11, 2018 8:45 pm
When it does this - start it, let it run chugging for a minute or two, shut it down. VERY carefully check the exhaust pipe temperature (I'd suggest an IR laser-thermometer) - see if one cylinder isn't running.
If it is one that isn't running - try swapping the primary coils from side to side. See if the non-running cylinder follows the coils. If it does that indicates a coil/ignition problem. If the non-running cylinder doesn't change - next swap the air adjustment steppers. They're identical and interchangeable. Does the fault follow the stepper? If not - we can eliminate the steppers.
Let it cool down a bit - and remove the primary plugs. Take a look - do they look identical? If not - photos of the tips would be helpful.
Possibilities I see:
1. Possible the steppers are sticky. The re-greasing would take care of that. And the test above would tell us if this is the problem.
2. Possible one of the primary coils is weak. The swap test is a good way to determine that - and reading the plugs will tell us if the bike is receiving fuel in the non-firing cylinder or not.
If one of the plugs is wet - that would indicate that injector is working and the plug isn't firing. If both plugs look identical - chances are it's not a fuel related problem.
This is one of those problems where careful diagnostics might turn up a clue as to what's happening.
Good luck, and let us know what you figure out or find..
Eagle6
Postby Eagle6 » Mon Aug 13, 2018 4:22 am
Thanks Don.
I'll keep all this in mind. With the issue bring random it may take some time to diagnose.
I may jump the gun and regrease the steppers to remove one possible cause.
Eagle6
Postby Eagle6 » Mon Aug 13, 2018 4:44 am
Don, I've just had a look at the LH stepper and the sleeve that looks like brass in your photos is a black plastic. Were the photos taken with a previous bike?
Postby deilenberger » Mon Aug 13, 2018 5:10 pm
Eagle6 wrote:Don, I've just had a look at the LH stepper and the sleeve that looks like brass in your photos is a black plastic. Were the photos taken with a previous bike?
These were on my '07 R1200R - I haven't done the ones on my '12 R12R yet. Is the sleeve plastic or perhaps black anodized aluminum?
Postby deilenberger » Mon Aug 13, 2018 5:13 pm
BTW - I'm actually surprised - the photos on that DIY were Photobucket hosted - and they still seem to appear. How about that..
Eagle6
Postby Eagle6 » Tue Aug 14, 2018 1:14 am
[quote="deilenberger"
These were on my '07 R1200R - I haven't done the ones on my '12 R12R yet. Is the sleeve plastic or perhaps black anodized aluminum?[/quote]
I would say plastic.
sykospain
Postby sykospain » Sun Aug 26, 2018 5:07 am
My recent experience points me at always - before investigating throttling, fuel-supply, sychronism and any other issues -
ALWAYS
rule out the possibility of a faulty stick coil.
Use the proprietary elegantly-machined alloy pulling tool ( the supplied plastic one often breaks ) to remove a stick coil - corrosion on the long outer sleeve leads to failure, which leads to rough running.
Eagle6
Postby Eagle6 » Sun Aug 26, 2018 11:02 am
Miraculously the issue hasn't raised it's ugly head since I posted the original query, so I haven't had chance to try any of the tests.
Was going to say I was looking forward to sorting out this issue but to be honest, of it's gone away I'm happy. LOL
Postby deilenberger » Mon Aug 27, 2018 10:48 am
Eagle6 wrote:Miraculously the issue hasn't raised it's ugly head since I posted the original query, so I haven't had chance to try any of the tests.
Since it might have sat for quite a while without fresh gas in it - it might just have been something like a sticky injector that has now cleared itself out with new gas.. wouldn't surprise me if you never experience it again.
Eagle6
Postby Eagle6 » Tue Sep 04, 2018 8:17 am
:p Took her out again on Saturday and everything ran perfectly.
Postby deilenberger » Thu Sep 13, 2018 5:20 pm
Eagle6 wrote::p Took her out again on Saturday and everything ran perfectly.
That's the best color BTW..
macmanaman
Postby macmanaman » Fri Nov 09, 2018 5:30 pm
Do you have enough slack in the throttle?
I have had this problem and it was due not enough slack in the gas throttle cable.
Regards from Spain
Return to “R1200R (2006-2014)”
Users browsing this forum: No registered users and 15 guests
