exterior temp gauge stuck on 73.4 F
LeonardoNYC
Postby LeonardoNYC » Sat Jul 27, 2019 4:07 pm
Hey all. Recently my temp gauge is reading the same temp see above. Wont' change. Anyone ever experience this? Any fix? Should I try disconnecting battery or anything else?
Thank you.
dbrick
Donating Member #: 902
Re: exterior temp gauge stuck on 73.4 F
Postby dbrick » Tue Jul 30, 2019 9:22 am
I have no idea. Could be the temperature sensor, the wiring between the sensor and the instrument cluster, the big connector at the instrument cluster, wiring in the cluster, or some solid-state circuitry within the cluster. Some of these might be accessible to you.
David Brick
Santa Cruz CA
dbrick
Postby dbrick » Wed Aug 07, 2019 9:23 am
Did you find a cause for this misbehavior?
David Brick
Santa Cruz CA
Return to “R1200R (2006-2014)”
Users browsing this forum: No registered users and 12 guests
