r1200gs compatibility
Just wondering if any one knows if a r1200gs (2006)stainless headers will fit my R1200r (2009)chrome .I want to replace mine as the are rusted and i can get a stainless header of a R1200gs from someone living 1000km from me so its hard to try it out.Thanks guys
- R12RnHouston
Re: r1200gs compatibility
Not sure, but it might be a direct fit. Check part numbers for both models in the microfiche at Max's or Bob's BMW websites. I've talked to the folks at Bob's on the phone in the past and they were really helpful.
You might also check some of the aftermarket systems and see if the same product fits across the R1200X family in your model year window.
Good luck!
Good luck!
07' R1200R Kristall Grau
ex 2007 F650GS
ex 2007 F650GS
Rusted? Doubtful since under the chrome is stainless.. discolored? Entirely possible - but the stainless ones also discolor to a poop-brown color instead of the blue that the chrome ones turn. Single wall pipes tend to do that.zackvis wrote:Just wondering if any one knows if a r1200gs (2006)stainless headers will fit my R1200r (2009)chrome .I want to replace mine as the are rusted and i can get a stainless header of a R1200gs from someone living 1000km from me so its hard to try it out.Thanks guys
Yes stainless goes brown mine is chrome. the front of the pipe is blue that's no problem .if the pipe is stainless under the chrome then it must be the chrome that is rusting .
I shall have to cross reference the aftermarket ones to check. The bmw no. Are different gs ends with 03 and 04 .mine ends with 05, 06.thanks for the quick response.
Chrome is copper, nickel and then a transparent layer of chromium. Just went and checked mine (chrome) - the header is non-magnetic so it is stainless. Puzzled, nothing there to "rust".. what does it look like? Any chance of a photo?
Thanks for that info .cant take a photo as i sprayed it black with heat resistant paint but that is starting to come off after 2 rides
It said can stand up to 650 deg but no such luck.
