The Mrs. got these for me for Christmas! $25 a pair, easy install and they look great. The only problem is I didn't have a 17mm wrench so had to make do with the ol' crescent.
http://www.amazon.com/Black-Motorcycle- ... I0FOPDCID2
Cheap LED turn signals for Jasper!
- ICBMguy
2000 R1100R Graphite & Ice Blue "Jasper"
Re: Cheap LED turn signals for Jasper!
LED turn signals don't work on the stock relay hence did you use resistors to get them turn signals working?
Brgds
Oliver
Brgds
Oliver
- ICBMguy
There's a Kisan SM installed already. I did not know about the resistor issue, good to know. Any idea what resistance is necessary? I assume something that will come close to a regular incandescent lamps resistance.
If you have the Kisan then it'll be fine. Kisan is LED compatible. The stock relay is not.
Brgds
Oliver
Brgds
Oliver
