Modifications to my F800ST
touchton
Post by touchton »
Here are the modifications I've done to my F800ST so far. The modifications can be categorized as 'safety' and 'convenience'. Obviously, the safety modifications are necessary because he's out there. And he's not alone.
The first safety mod is the addition of MotoLights. I had MotoLights on my R1150R and really liked them. The R needed the additional lighting for night driving as well as providing better daytime visibility. The F800ST has much better lighting for night driving but still needed something to help with daytime visibility. The next two pictures show the caliper mounted MotoLights and how I mounted the switch to the dash.
The second safety modification was to replace the rather wimpy horn with something that can get a clown's attention. I did a similar mod on the R where I placed dual FIAMM Freeway Blaster horns under the beak. It worked great and sounded like an old Buick. I couldn't find room for the dual Freeway Blasters on the F800ST. I wound up with a pair of PIAA disk horns (high tone / low tone). I mounted these in the same general area as the original horn. I had to fabricate a couple of mounting straps. It's louder, but not like what I had on the R.
Now for the convenience modifications. I installed a Garmin Nuvi 660. It's wired to the GPS power connector so it powers up with the ignition switch and turns off about 60 seconds after the ignition switch is turned off. I mounted the GPS to the handle bars using the standard RAM mounts.
I installed a Signal Dynamics LED battery gauge. It uses a single led to indicate the status of the battery/charging system. I wired it to the same power as the GPS. Since the LED stays on for about 60 seconds after the ignition switch is turned off, it looks like my bike has an alarm installed.
I also installed a larger foot for the side stand. I purchased this foot from Ilium Works. There are two models for the F800ST so you need to measure the length of the original foot to get the correct one.
And I added a tank bag. The dilemma here is I really don't have a 'tank' to deal with. I went with a 6L Marsee bag using the Corona mount. Typically, this mounts to the gas cap of the tank. That would put the tank bag just behind my right hip. So, I drilled some holes in the electronics cover and mounted it where a 'tank' bag was intended to be.
I have it just about the way I want it now. I do need to move the control wire for the MotoLights though. I used a switched power wire to control the relay and I need to use low beam power like CycleRob did. That was my original intention, but this other wire was so much easier to get to.
Thad
wncbmw
Re: Modifications to my F800ST
Post by wncbmw »
Thad - the tank bag installation came out great! Looks good.
And from our ride the weekend of the MOA, I can attest that the Motolights really make you show up from way down the road! :smt023
Vann - Lifer No. 295
touchton, Nice work. The tall triangle daytime light pattern connects immediately with oncoming car driver's brains as "danger". I'm really glad you're slowly breaking out of what I consider your biggest and as far as I know, only flaw: excess modesty!! :-" I'm basing that on the AFAIK never documented clean farkle installations I noticed on your 1150R when it was here for the tech session.
FWIW, I had a strong restraining mental block about drilling into the top plastic panel, a permanent modification scar :shock: for my GPS RAM mounting. My current prototype #2 needs to be redesigned to use the the same 2 center top screws and a drilled in the plastic :smt103 front edge center hole to complete the new fanatically minimalist RAM support tripod. That'll give no direct contact with the frame which the 2 front legs right now transmit some v-low amplitude vibration to the GPS. I want it as near zero as possible.
About adding a more powerful horn, I transferred my salvaged but near new Yamaha R-6 disc horn from the 50R to the F800 using the same wires and relay. It needed a new longer bracket to mimic the BMW original. In the new bike it required a 1500ma rectifier diode to be used as an isolation diode (it absorbs spikes) between the relay coil and the stock horn's power wire. Here's the pics during installation:
Image Image
The 2 horns together when blown at pedestrians 10 feet away generates a tall air space under their shoes.
BTW, my bike just passed 2,200 miles.
Edit: To add Thumbnail Pic and change photo host away from PhotoBucket to Postimage.
Boxer
Donating Member #: 2
Post by Boxer »
Thad. Nice work, as usual. I particularly like the larger sidestand footprint. That whole sidestand looks a little "flimsy" if you ask me. But I keep looking at the ones on the GSs, and that looks like overkill in the other direction.
I saw that volt meter "light" at one of the web sites. I might use that idea as well when the time comes. But I might wire it so the little lite is always on. (Rob's gonna give me that shaking finger for that idea.) But I don't think its much more draw than a clock, if even that.
Boxer wrote:I saw that volt meter "light" at one of the web sites. I might use that idea as well when the time comes. But I might wire it so the little lite is always on.
#-o [-X
This was accomplished months ago, but I waited so there is no question now about it's durability, and I can therefore recommend it. The sidestand got so hot after welding that the water I slowly dunked it into flashed to steam.
No more worrying if the tiny stock sidestand foot will dig in hot tar or a firm lawn and cause tipover damage. Yes, I carry a 4" (102mm) blue plastic disk made just for that purpose (an Insurance Co promo), but the welded on foot is always there and more importantly, never forgotten.
EDIT: To change photo host away from PhotoBucket to faster, less intrusive Postimage.
Buckster
Donating Member #: 543
Post by Buckster »
Nice mod....I wonder why the EOM stands wouldn't come that way....it just seems silly to me.
Buckster '03R
#543
touchton
Post by touchton »
Just got a Sargent seat and a LED tail/brake light for my F800ST. I won't have a chance to install either one this weekend, but hopefully I'll get around to in next week.
Another little gem added to my ride. I was thinking of adding this to the "Little things, greater satisfaction" post, but the part that was added extreme lack of availability pushes it into the more adventurous "mods" post. The rubber cable bellows was salvaged from a damaged/discarded clutch cable from a Japanese SportBike. I stumbled upon it looking in my "good junk" pile for something else and :smt007 knew exactly what to do with it! Unfortunately, that protective rubber cable bellows, in all my past experiences, is not available individually. In this picture below, besides that rubber protector there are 2 other mods that have already been documented.
BTW, Having lived 58 years in CT & PA, all you Northerners still getting even more snow, yesterday I went for a 22.1 mile (35.5km) ride in 55DegF (12.8DegC) sunshine about 4PM when my self imposed chores were completed. That was with no long-johns or my usual ski over-pants! Really runs sweet in the cold weather. When I turned the key off after the ride, I couldn't help but feel great about the whole experience, knowing exactly how nasty it was in freezing Chicago for my buddy OU812 the same exact moment.
If you ever see or sit on an F800S or ST model, one of the first oddball things you'll notice is the very out-of-place, tall and lanky front brake reservoir bracket. It holds that translucent plastic container waaaaay up there and waaaay out there, like it's definitely not the correct part. Really really bad! #-o From what I have read, the F800S and ST models originally had one like the K1200 bikes that mounts directly inside the master cylinder body. Then frothing of the brake fluid from engine or road vibrations caused air pockets where air should not be. The remote isolation bracket solution they came up with looks like it was a parts bin piece from an ATV. Hideous and misaligned. I disliked it so much I tried to see how easy it would bend as soon as I got home on day 1. Some riders have even spent the ~$45 for that K1200 reservoir, bolted it into place, and not reported any brake problems. That was just too expensive to me for just a cosmetic change. My answer, the usual: Make one from nothing. The "nothing" I used was a small rectangular .086" thick steel bracket used to hold wooden GoldWing crates together. I have a cleaned gallon paint can full of them that were salvaged during my early 1990's part time job in the Manchester (CT) Honda shop. The solid (good) crate wood was also discarded! Some of it became very sturdy Table/Bench/Shelving frames for the workshop, joined together by those same 2"x4" steel brackets. Anyway, those steel brackets are the gift that keeps on giving, now 18 years later, because of their convenient size and awesome strength:
To start off, the old reservoir bracket comes off. Then I just grabbed the still hose attached reservoir and pulled it to the place where it belonged AND the new gentile bends of the hose allowed it to go. Next comes the hard part. Creating an accurate template made from cereal box cardboard so the steel one cloned from the template will fit perfectly. Here is the product developmental prototypes with the obvious, easy steps left out.
Click Thumbnails below, then click the big pic to go full size:
Image Image Image Image Image
As you can see, it is so pulled down-and-snugged-in that it looks like BMW did it. It no longer pisses me off like when I see that stock front brake reservoir. It even looks normal for the Hi Tech bike it's mounted on.
Here's another small mod that's totally hidden. The coolant recovery tank cap's added on top vent hose is about 6 inches long going straight up to nowhere, capturing minute coolant drops within it's sidewalls that later combine then drain back in. A tiny paper towel wad stuffed snuggly in the end contains water vapor and excludes road grime. The brass fitting drilled then screwed into the top of the cap came from a broken throttle cable. Since the clear hose has a slightly larger diameter, an interference fit was necessary. No more hot coolant odors or road bump induced weeping from an almost too full recovery tank.
Mollygrubber
Donating Member #: 741
Post by Mollygrubber »
I love reading your posts, Rob. Makes me want to get an F8--- and 'fix' it.
2010 F800GS
Member #741
Thanks.
Luckily, there aren't too many things that need "fix'n".
About the handmade bracket, I forgot to mention that the 2nd prototype's unique narrow waisted twist-n-turn shape
was intended to serve as a vibration damper. That's why the hideous stock bracket
exists in the 1st place!
So . . . . I closely studied the stock bracket, knowing lots of computer design time and brainpower must have been invested in it. Two big bends sharper than 90 degrees. The off-axis extension. An odd 4 sided cut-out mid length and the large metal mass area where the reservoir attaches surely have designed in dynamic tuning functions. Minimally thin in the middle and heavy at the end. Look at that top pic link above again. I incorporated all those basic design concepts from the clumsy looking stock part, only in a more graceful and very compact way. It's equivalent to a long narrow bracket, just coiled up to save space and putting the reservoir where it belongs. The greater length of a straight, narrow band bracket dampens forces on the X & Y axis’s but not Z. Twisting it the way I did significantly covers all 3 axis’s. I bet you thought I was only trying to make it look cool.
BTW, For many months there have been no DOT-4 fluid frothing issues whatsoever.
Axis Info:
X=Left/Right
Y=Up/Down
Z=In/Out
Mollygrubber
Ahhh... now I understand: "Enjoying retirement in Gainesville"
From my perspective, you are a lucky dog.
Did you ever consider showing that mounting bracket to BMW? It's genius, and should have been done in the factory, IMHO.
2010 F800GS
Member #741
BMW will find it here, I'm sure. It's not that they aren't capable of making a design like that. Maybe they didn't have enough time when the "problem" surfaced and used a bracket from another bike. Maybe the harmonics for a compact one similar to my design wasn't good enough. Looking at the stock bracket, everyone almost says out loud . . . "WHAT were they THINKING??" #-o 8-[ [-( It doesn't even hold the reservoir level! :shock:
Genius? All I did was grab onto the hose attached reservoir and pull it into place, low & tight, then note the new 2 dimensional spatial coordinates of the 4 bolt holes by looking downward from above. Transfer that to the paper template, then add the 3rd dimension by lifting up the reservoir mounting holes, leaving a snakelike connecting link in between the 2 mounting points. Bingo. The bracket comes to life. A few hours of cutting, drilling, filing, bending and finally painting is all it takes. :-"
Buckster
Post by Buckster »
=D>
Great job!
You must love tinkering....I love it too!
Buckster '03R
#543
My latest mod . . . painting the stock windscreen black.
I have wanted to do this since last year. I've first seen this type of mod performed on the stock windscreen of an R-6 Yamaha SportBike many years ago. Even on close-up inspection, It looked fantastic! The balance of the black seat/tires/windscreen parts to it's deep Yamaha blue solid color paintjob was very classy looking. I'm not sure if he sandpapered the windscreen's backside to strengthen the paint bonding, but I sanded mine with #400 grit until I could not see thru it. No turning back now! Laid it front face down on a 1 foot square folded towel, then applied 2 coats of Rust-oleum gloss black rattle can spray paint. Several hours drying time in the fierce Georgia sun between coats, and afterward.
Here's 2 more pics:
Image Image
Riding the bike, the 3 LED voltmeter seems brighter in the subdued lighting. In bright sunlight, the instrument cluster wasn't much different. The forward view blockage is almost zero, because the shallow angle it's at in your field of view means you're not really looking thru very much of it to see what's in front of you. I haven't ridden it at night yet, but I'm sure the experience will be different. The paint surface of the backside is very rough looking, but not noticeably visible unless you intentionally look there. I am very pleased with the result. :smt045 :smt023 :smt055
Buckster
Post by Buckster »
Looks good! 8)
Buckster '03R
#543
Click Thumbnail below.
These straps are a simple little thing, but they again turned out to be very useful. I confess that the bungee mount straps were installed on my other bike, but before that they were an OEM installation on an R-6 Yamaha SportBike that became a dedicated racebike. That same bike also provided the same new horn used on the 50R and F800. On the R1150R, there already were threaded holes in the seat base, originally for the passenger hold-on seat strap . . . that got removed on day 2. :smt045
The original plan was to drill a bolt hole, then about an inch (25mm) away a larger hole, to be used as an insertion point for the washer and nut. After I drilled the first pilot hole, the plastic was so thick, I realized it would be strong enough to be threaded. Making the threads, I didn't go the full tap depth that would have made a completed thread. Going part way provided a tighter female thread so the bolt would not come loose. I used a short 6 x 1.0mm hexhead bolt inside a short collar so the bolt could be tightened against the short collar. You can make your own collars by cutting a length of small Aluminum or Brass pipe with an ID slightly larger than the OD of the bolt threads. The 2 thickness’s of Nylon strapping are as thick as the collar is long, so the strap stays where you swing it to, and with the smooth surface, larger diameter collar, the holding shear strength is high. A short blast from a Propane torch melts the fuzz cuts or strands into a nice smooth surface.
I've very tightly bungee strapped a full 5 gallon red plastic fuel container on behind me using both straps with no loosening, so they are sound. The straps provide a hooking point that's conveniently where it needs to be -and- that hooking point swing-stores away under the seat when you don't need it. :smt023
So there you have it. Another simple useful mod that some of you tinkerers can do at little or no cost, if you are resourceful. More important than the no cost is the premium quality of nearly ALL the salvaged parts being used.
storman113
Post by storman113 »
Touchton
"It's wired to the GPS power connector so it powers up with the ignition switch"
Where would one find the GPS power connector?
I really enjoy reading the mod's on this forum. :D
'09 F800ST, Midnight Blue
touchton
Post by touchton »
The GPS connector is wrapped up on the right side of the battery. You can buy a special cable that fits the connector, but I just cut the connector off and hardwired it. Electrically, this does energize with the ignition switch. When you turn the switch off there is a 30 or 60 second overhang, so it doesn't power down immediately. I also have my LED battery gauge wired to this circuit.
