Folks,
I keep hearing all those stories about how removing CCP (coding plug) does wonders to a bike. Well did that on mine. No workie. Bike wouldnt even start without CCP. Does that CCP removal trick only work for single ignition 1150 and 1100s ?
2005 rockster CCP removed, no miracle???
Re: 2005 rockster CCP removed, no miracle???
Are you sure you removed the CCP and not something else??
riceburner +1, Yes you removed the wrong one.
The CCP is located in the middle row, starting from the left there should be a hole (US bikes) and then a Yellow (US bikes)plug in on a WHITE BASE that's the CCP. Make sure you reset the ECU.
Good luck
Good luck
