I see on Bob's BMW website they have a bolt on side stand foot enlarger made of billet aluminum. That looks like a great idea to me. The only problem is they don't list one for the R1150R. Anybody know of a different source for this or if the 1150R sidestand is the same as something else??
Larger sidestand foot
Re: Larger sidestand foot
Won't the enlarged foot get in the way when you try to put down the main stand?
I frequently kick the bike into gear which then makes it difficult to get upon the stand.
I've got large feet though, UK size 12 (US 13).
The sidestand plate is in the Wunderlich catalog. If I get a chance later, I'll post which page it's on.
Yes, you will need to alter your centerstand deployment technique, but I'm sure you can handle it. I'm not too smart, and I wear size 12 boots, and still managed to figure it out.
I think it's so worth having, that when I lost the first one because I didn't think about putting Loctite on the screw threads, I promptly ordered another. This one has stayed put for 8,000 miles.
Anthony
Member since Dec '03
2003 BMW R115RT-P
2006 H-D FLHPI
2003 BMW R115RT-P
2006 H-D FLHPI
Yes- loctite the screws or bed the base plate on with silicone sealer. I too lost my first one!
Also, the enlarged foot was very very close to the exhaust system on my bike so I carefully shaved some of the foot off with the bench grinder to give 5mm clearance. Without that, every time I put the stand up it hit the exhaust. Use some black metal paint to cover the bare metal!
Wunderlich part no. 8500024The sidestand plate is in the Wunderlich catalog.
Life Member #551
02 Blue BMW R1150R non-ABS
Make your own.
They cost like $35 which is pretty high i think.
I just got a 1/8" piece of aluminum cut, file round,etc. to fit.
Drilled three holes and tapped them.
Loctite in the threads.
Seems like alot of work but can be done as time permits if your not in a hurry.
Micky
Micky
Micky
2000 Moto Guzzi Jackal
2004 Rockster - Green
Bob's BMW makes thier own version, it works great no problems. Remember to locktite the screws!! Can't remember the price. But his throttle lock is better and cheaper then the others out there.
Michael
MG 78 LeMans
2002 R1150R
78 R100S
MG 78 LeMans
2002 R1150R
78 R100S
My poor man's solution was a galvinized cover plate from an electrical junction box. I attached a length of nylon cord to it that I loop around the handlebar when the plate's in use so I don't ride off and forget it.
Fit's easily in the tank bag, works like a charm and best of all, the total cost was about a buck.
Charlie
Charlie
'03 R1150R
Life member 365
Errabundi Saepe, Semper Certi
Life member 365
