01 Rt1100, same engine as roadster.
I know the setting to use but I can't figure out where to stick feeler guage.
I've set valves all my life on all my cars, normally between rocker arm and valve stem.
On this bike there is a cone between rocker arm and valve stem.
Where the $%& do I stick the feeler guage to set them? There is no flat place i can see, even after watching youtube vid...
problem setting valves
Re: problem setting valves
I found out how to set valves on another forum
http://advwisdom.hogranch.com/Wisdom/JV ... djust.html
Very good pics and description.
Same setup as all oilheads, looks like to me.
Folks,
this http://www.advrider.com/Wisdom/OVADv2.2.pdf is by far the best instructions about adjusting your valves I have ever seen ...
Brgds
Oliver
Brgds
Oliver
