MFW Vario pegs or Suburban Kit
Hello all, Going to lower pegs (knee injuries) and I am debating between the MFW Vario pegs with the 30mm extension or the Suburban kit. I'm probably going with the Vario (looks cleaner and seems adjustable to a point). Any thoughts from those that have one or the other? An fitment issues? Thanks in advance...
- AncientMariner
Re: MFW Vario pegs or Suburban Kit
I have the Suburban kit. It is so well interated with the bike that I have to actually point out the various bits. My knees have been much happier snce the install.
Install was very easy.
Do a search on me and footpeg lowering to see pix and read all about the project.
Bruce
Bruce
'13 R12R Montego Blue
'95 Mystic Red K75
'94 Black HD FXDS
'95 Mystic Red K75
'94 Black HD FXDS
+1 on the Suburban kit. Very well made.
Kevin Huddy
Intrepid Incompetent
Canyon Creek, MT
Canyon Creek, MT
My bike also has the Suburban kit, but I ended up fabricating a new shift lever to get the shift tab where I wanted it: further forward, out, and down a bit. YMMV.
David Brick
Santa Cruz CA
Santa Cruz CA
- Bob Ain't Stoppin'
- Member
Installed the Suburban peg lowering kit the other day. Very easy to put on. I don't generally have issues with my knees, but have found that after 6 hours or so, the R position leaves me a bit cramped. But I have other hopes for this kit. There is more going on here than lowering your feet, and thus easing the knee bend. This slight move in the feet also changes the angle of your hips and helps to straighten your lower back. Another side benefit is that the resulting hip bend tends to bring your hands more readily to the grips. I think the peg lowering is going to be a major improvement to long ride comfort for me due to all these changes combined.
Thus far I've got about 2 hours time with this. More time will help me cement these impressions. Perhaps I'll report back then.
Bob - Don't forget to post your height and inseam. Major issues when talking ergonomics, it will give a better idea of who will be interested in your modifications.
2011 Sportster
2011 Sportster
- Member
Sure. I'm 5'11" with a 30 or 32 inseam.
I've had the Suburban Machinery kit on my '07 for 4.5 years. It integrates very well indeed and simply appears to be part of the bike - most variable pegs look a bit like an afterthought to my eye.
I'm no hoon (Hi, Joe) so I have never come close to touching a peg or my boot - my "chicken strips" on Meteler Z6 tyres are about 1cm (0.4"), I I do go "over" but not rght to the edge!
To demonstrate the wide application, I'm 5'8" with a 28" inseam and Euro size 42 boots. I've mostly used a 780mm low seat, and also now have a 800mm seat (low comfort seat) as well.
The knee relief offered by -40mm is great, and combined with the +20mm of the comfort seat is a much more comfortable distance ride (I'm set up to tour). With 25mm bar-backs (MV Verholen) my ride position is clsoe to perfect for me and my riding style.
Hi All,
New to the forum as I just bought my '07 R1200R 2 weeks ago. I have been trying to find out which seat height I have on mine. The only numbers I can find stamped on the seat are:
163609-10
7 697 216-05
Does anyone know the number schemes for the 3 different seat heights so I can determine which seat I have? If mine is the standard height, I will definitely be interested in acquiring a low seat. If I already have the low seat, I do not want to by another low one.
163609-10
7 697 216-05
2006 Suzuki Katana 600
I don't think the numbers under the seat change.. those are in the pan. You could try punching the numbers into the PN lookup on www.realoem.com and see what comes up.
To tell which seat you have - take a few photos of the seat from the side and post them here.
Cant he just measure from the ground to the seat? I found these specs online: 800 mm (low seat: 770 mm, high seat: 830 mm), which makes the standard height seat 31.5", which is consistent with some other specs online.
John K
2008 R1200R
2013 HP4
2008 R1200R
2013 HP4
Could be a recent thing, but there's a production sticker on the underside of my (model year 2011) seat that identifies it as "Komfort Sitz NORMAL" so I'm guessing I have the standard height comfort seat.
Don't know when BMW started this practise, but it might be something to check.
Chuck
Chuck
Chuck DeSantis
11 R1200R
75 850 T3
73 Eldo Project
K75C <RIP>
K1100LT <Sold>
11 R1200R
75 850 T3
73 Eldo Project
K75C <RIP>
K1100LT <Sold>
I measured it while someone held the bike upright. Must have the standard seat as it was a smidge over 31.5". Thanks for the help. I'm going to keep an eye out for a used low seat and give it a try. Hopefully it's more comfy than the standard, but I won't hold my breath.
I have one off an 08.proudpa9697 wrote:I measured it while someone held the bike upright. Must have the standard seat as it was a smidge over 31.5". Thanks for the help. I'm going to keep an eye out for a used low seat and give it a try. Hopefully it's more comfy than the standard, but I won't hold my breath.
Kevin Huddy
Canyon Creek, MT
Canyon Creek, MT
