Shocks
Shocks
Was wondering if any mods can be done to stock shocks on a 97 r850r, have adjusted rear all the way and still seems like it hits way too hard over bumps( actually doesn't seem to make much diff where I adjust it) and if not any suggestions for a new one, bike has just over 49k on it. Thanks for any input. Mike
Re: Shocks
Stock shocks can be rebuilt - mine were yoast almost bang on 25 k miles. Same symptoms as yours
Re: Shocks
I didn't realize they could be rebuilt,will look around to see, do you know who rebuilds them offhand?CycleRob is going to pull the trans and lube the splines , thought it would be a good time to do something with the shocks kind of a old bike to put that kind of money in , but she runs sweet and I am growing fond of her. Thanks
Mike
Mike
Re: Shocks
I can give you details of a couple of companies here in the UK but none in the US I'm afraid
Re: Shocks
Mike,
suggest you search the forum. Has been discussed previously. There are shops in Europe and in the US of A who rebuild shocks and even change the springs. Actually if your shocks might feel very hard it maybe that you need a different spring.
Brgds
Oliver
Brgds
Oliver
Re: Shocks
Thanks for the reply, I have searched the forum just seeing if anyone has in new input. I am thinking the the spring is too soft and bottoming out, will get a friend to help hold the bike and check the return rate after compressing them . Probably try the Hagons if needed.Have a good day. Mike
Re: Shocks
If they are not leaking get the springs fitted from Hyperpro. They are progessive springs and they really make the bike so much more comfy. No problems on bad roads now .
Re: Shocks
Finally mounting new Hagons on the r850 and realized I dont know where to mount rear remote adjuster. a picture would be nice , thanks in advance.
Mike
Mike
Re: Shocks
This topic has been resolved here in the R1150R section: http://r1150r.org/board/viewtopic.php?f=2&t=31202
