GPS mount
Re: GPS mount
You can probably get a RAM mount - pipe-clamp that should work.
Re: GPS mount
Cheers Ricey, I did have a mount but sold it, think the one I'm after is a Touratech one.
Re: GPS mount
I got a SW Motech mount from Twisted Throttle. The base mounts using the four bar clamp bolts. I'll take some pictures and upload them shortly.
2004 Citrus Green Rockster, 2005 F650GS
Re: GPS mount
The base:
The bottom view of the adjustable mount:
Installed using a RAM diamond base and RAM nuvi cradle:
Re: GPS mount
Thanks for the photos, it is very similar to the one I had, which was fixed the same way but just had a round bar to fix the Satnav cradle.
What Satnav do you use with it?
Re: GPS mount
I'm currently using my auto Garmin nuvi 1350 in the cradle. Not waterproof, but I just bring along a clear Zip-Lok bag to cover it. Worked well on a 3700-mile trip last spring on my F650GS. I've only used this mount on the Rockster a few times but I like how I can adjust the angle of the GPS unit for my dingle sight lines.
The mount slides into the raised 'U' on the base and locks securely. A plastic latch is then depressed to slide the mount out from the base. It has some internal dampening and the RAM ball also keeps it from vibrating.
Re: GPS mount
I have a Garmin car gps and just put suck it on the speedo glass. Works well, but I do have a screen and asso have a safty cable on it on the off chance it comes off. The gps gives me my speed.
To easy.
To easy.
Re: GPS mount
I've got a Zumo 660, so going to get an SW Motech mount I think.
Anybody use this mount and if so, what's it like.
