Remus header pipe question
- citrusbbee
- Triple Lifer
I've installed the Remus header pipes on my 2012 R12R and it fits great with one exception: the rubber centerstand stopper no longer lines up with the tab on the stock can. The stopper is an inch or so away (towards the front of the bike) from the tab. Has anyone else had this issue?
Citrusbbee
Member #553
'04 Rockster Ed80 (#967)
'15 R1200RT
Member #553
'15 R1200RT
Re: Remus header pipe question
Seems you need at least some sort of response.
I have a full Remus system on my 2007 R1200R, and am not having the issue you describe.
There is some adjustment and slack in the pipes, so you may just need to loosen all the clamps and slide the pipes around so they line up with your stop correctly.
Good luck!!
Good luck!!
R1200R, R1200RT, R1200GSA, R100Mystic, R90S, R100RS, R100RS CFO
