FYI Installing T valve stems for TPMS
I installed an In-command TPMS system on my R1150R That apparently is NLA
It was a phone AP based system that will alert me thru my Sena headset
It uses the valve cap type sensors
Their are many other brands still available that use the same type sensor
To make inflation easier I installed T stems from Cyclemax
They are a Gold-wing parts House
https://cyclemax.com/inc/sdetail/chrome ... 102/261164
The T stems work very well but require the flange be tapered and the OD be reduced to fit down into the countersink in the wheel
This is very easily done by chucking the stem in a drill and spinning flange against a file
82 R65
04 R1150R
04 R1150R
Re: FYI Installing T valve stems for TPMS
Here is another System
https://www.northerntool.com/shop/tools ... gK-IvD_BwE
82 R65
04 R1150R
04 R1150R
No Longer Availablericeburner wrote:NLA?
82 R65
04 R1150R
04 R1150R
I've been running one of these for the past 18 months or so. Works very well and is accurate. I use them on the rubber valve stems (which I change at every 3rd or 4th tire change) - And don't bother with the lock nut. If I need to air up... Just unscrew the cap and top up.
Very impressed with it and relatively cheap. An alternative.
CAREUD Motorcycle TPMS Tire Pressure Monitoring System Wireless Digital Tire Pressure Gauge Tire Leakage Alarming System Waterproof 2 External Sensors Seller Mehart Cheater Hijack, Read Their Feedback https://www.amazon.com/dp/B076KKYDRQ/re ... -EbK351B0D
Not to be an alarmist....a friend was running a screw onto the valve stem style of TPMS.
While riding with his wife on the back it pulled the entire valve stem core out at speed.
They didn't crash, barely.
I had a OEM system on a Kawasaki Concours 1400 that was internal to the rim.
It wasn't worth having.
1974 Kawi H-1 500
1975 Norton 850
2002 BMW R1150R
2008 Suzuki Bandit 1250
2013 BMW GS 650 Sertao
1975 Norton 850
2002 BMW R1150R
Not sure how it could pull the valve stem core out
It does not attach to the core it only presses on it
Are you sure he didn't loose the whole stem
Was it rubber?
Was it rubber?
82 R65
04 R1150R
04 R1150R
Just the core and yes it was rubber. FJR-1300, not a older Motorcycle.
I have also heard and read about balancing beads causing air loss failure in vales stems.
I'm sure there are many who have used them for 1000's of miles.
I will never be one.
1974 Kawi H-1 500
1975 Norton 850
2002 BMW R1150R
1975 Norton 850
2002 BMW R1150R
All The manufactures of this type of TPMS recommend metal stems
82 R65
04 R1150R
04 R1150R
