Need help finding brake part
2004 R1150R On the rear brake pedal there's a clevace (a U-shaped fitting) that connects the rear of the brake pedal to the push rod that goes up into the master cyclinder. Mine fell off somewhere in the Arkansas Ozarks about 400 miles from home. Now I can't find the part anywhere. Beemer Boneyard won't sell the clevace alone. I'd have to buy the entire master cylinder assembly. I've been able to find a retaining pin/clip and the push rod but can't locate a clevace. Any help would be greatly appreciated.
2004 R1150 R ABS
Lincoln, Nebraska
Lincoln, Nebraska
Re: Need help finding brake part
repsycle may have them
Jeff (lifer #289)
'17 F800GSA
'04 R1150R
'17 F800GSA
'04 R1150R
Thanks, I found a used master cylinder on Ebay for $20 that had the fitting on it. Problem solved.
2004 R1150 R ABS
Lincoln, Nebraska
Lincoln, Nebraska
