Minor oil leak after oil change
Changed oil (and filter) on my '04 RR the other day. At the end of the test ride I noticed a drop of oil hanging at the bottom of the oil filter. At the time I thought that was just residual stuff that got squeezed out as I put the oil filter on.
However, I do notice a fresh drop of oil hanging at the bottom of the filter after every run.
The oil level (currently a hair below the mid-point) has not changed even after the bike has been ridden for about 200 miles after the oil change. It's clearly a very slow leak.
Could it be that the rubber ring at the top of the oil filter has not seated properly? I smeared the ring with fresh oil and then torqued the filter on to spec. Should I repeat the oil change?
Thanks.
Thanks.
Take some carb cleaner and spray it up into the recess of the oil filter housing (the filter remains in place) to remove any residual oil. Repeat this a couple of times to ensure you have removed any lingering oil. Take the bike for a ride and see if it leaks. If it does, then there may be something wrong with the filter gasket. Was this a BMW filter?
Tony
Tony
Thanks Tony. I'll try that.ProductUser wrote:Take some carb cleaner and spray it up into the recess of the oil filter housing (the filter remains in place) to remove any residual oil. Repeat this a couple of times to ensure you have removed any lingering oil. Take the bike for a ride and see if it leaks. If it does, then there may be something wrong with the filter gasket. Was this a BMW filter?
Tony
Yes, it is a BMW filter.
Just undo it a 'smidge' (1/4 turn) and re-tighten it (1/3 to 1/2 turn).
As we all know it should not leak - installing one is not rocket science.........if it continues to leak however you should remove it and have a good look for an obstruction on the seal (possibly a little 'nick') or maybe something on the mating surface? If somehow there is an obstruction preventing a seal then it is possible that it might actaully come off!!!!
Remember a little oil seems to go a long way - for any sort of oil leak to impinge on the oil level it has to be a major leak.
Everyone is entitled to my opinion!
The couple of drops would not show up as a drip. As the other guy said, try retightening the filter, or do the job over again. I know from my own experience that you could loose almost all the oil before you know whats happening. Did it in a dodge pickup. Lucked out though, no damage. Peace of mind and knowing the job is done proper is always best.
