Instrument Panel
Posted: Wed Aug 27, 2008 6:21 pm
by abrinton
I recently purchased a 2001 R1100R. I also downloaded a service manual. However the manual does not show or explain all the lights on the instrument panel. Some are obvious, but can somebody explain the layout or tell me where to access a graphic with identifications?
Re: Instrument Panel
Posted: Thu Aug 28, 2008 1:25 am
by sweatmark
Your 2001 has same instruments as R1150R Roadster. Turn signal indicators, neutral, high beam, low fuel, charging system, and oil pressure. If you have ABS, then the remaining two lamps provide fault status for the brakes; otherwise those indicators are blanks.
Posted: Thu Aug 28, 2008 4:00 pm
by abrinton
Thanks, that makes sense.
Posted: Wed Aug 24, 2016 9:40 am
by 3jsdaddy
Hello,
I've just purchased a 1997 R1100R. It didn't come the riders manual, so I'm ordering one. But in the meantime can someone could post a picture of the dash & what lights mean what? I have a solid red light in the lower right that I'd like to know what it means.
thanks,!
Posted: Fri Sep 02, 2016 8:36 pm
by rsc
Like this?
Instrument Panel
Posted: Sat Jul 14, 2018 8:59 pm
by MichaelCew
I am installing the CH650 canopy on a CH601-HD.
Could someone tell me what is the CH650 instrument panel width?
On the XL, it is part number 6B12-4, 938 mm wide. I believe the CH650s panel is just a bit narrower...
Thanks in advance
Carlos
CH601-HD, plans
Instrument Panel
Posted: Sat Mar 23, 2019 6:57 am
by Henrysheem
This instrument panel looks different to my P3 75 six-light 1948 Is it possible there were multiple versions? Could this be a P2 instrument panel?
