Hi everyone,
I recently got myself a nice LiFePo4 pattery pack from China (through fleabay). It took 10 days to arrive and did not get stuck in customs
I got my battery here http://myworld.ebay.com/sz_ohmygod/?_trksid=p4340.l2559 and it is a 12 cell 13.2 V / 6.9 AH (which is good enough for our oilheads).
I got myself a nice housing (waterproof). Drilled 2 holes in there for the cables to come out. Applied some foam padding inside) and in goes the battery pack. The result is a small case on 120 x 120 x 90 mm with a total weight of 1277 grams. Photos here https://picasaweb.google.com/1003408169 ... o4Batterie
I have not yet installed the battery hence tests are yet to follow. The overall cost have been very reasonable I must say. And the weight saving is noticeable!
Brgds
Oliver
LiFePo4 battery
- The Meromorph
Re: LiFePo4 battery
A few people over here in the US have been trying Shorai Lithium Ion battery packs. Racers are unequivocally delighted with the weight saving, and find performance completely satisfactory.
On the road users report mixed levels of satisfaction, for two reasons.
This type of battery is very temperature sensitive, and cold starting with the battery under 40F is problematical, under 30F requires the battery to be warmed up before the bike will start.
This type of battery has a very low capacity to handle parasitic drains. Even a clock will have the battery unable to start the bike after a month of non-use, and an anti-theft system, or any drain larger than 0.1 amps, will have the battery dead flat after less than a week. And they are damaged even more than Lead/Acid cells by running them completely flat.
HTH. Good Luck.
HTH. Good Luck.
Re: LiFePo4 battery
I fitted one of the Shorai batteries to my R850R, a couple of months ago.The Meromorph wrote:A few people over here in the US have been trying Shorai Lithium Ion battery packs. Racers are unequivocally delighted with the weight saving, and find performance completely satisfactory.
I was super impressed by the lightness, I think there was about a kilo and a half saving compared to the original lead/acid one.
I'm not a racer, but I am also not as fit and strong as I used to be, so any weight saving, especially quite high up, is a bonus for me.
Living in Sydney, Oz, the cold starting hasn't been a problem, and we don't tend to leave our bikes unused for any great length of time, either, so I am very happy with the Shorai.
So far, so good...... so far so good.....
regards,CrazyCam
Re: LiFePo4 battery
As I said, testing will follow. But as a matter of fact my regular battery was also dead after a month or so because of parasitic drain (clock, etc). Hence I will either disconnect the battery or keep it on the charger ...
At the moment we are at -4° C at night and around 6° C during daytime. I'll probably put the battery in over the weekend and then see ...
Brgds
Oliver
Brgds
Oliver
Re: LiFePo4 battery
OMG Batteries ?omg1010 wrote:Hi everyone,
Are you trying to sell your own products here ?
Greetz, Erwin
2003 Rockster Full Black
Re: LiFePo4 battery
Hello Erwin,
why don't you just keep your fingers away from the keyboard? I have been posting enough here to prove that I am not from China and that I am not trying to sell anything to anybody.
Brgds
Oliver
Brgds
Oliver
Re: LiFePo4 battery
Don't know about the Chi-com battery, but just put a Tek in a buddy's R100 SRS. Its cranking power is pretty cool, it didn't have the ole airhead start. It fired up quick as a hiccup. We just had to augment the box because it is considerably smaller.
"You are a unique person, just like everybody else!!” - Warren Miller
Re: LiFePo4 battery
Yes correct, the cranking power is cool. And yes the battery is considerably smaller than the stock or the widely used Odyssey PC680 battery - hence some rubber foam will do the job and fill the gaps ...
Brgds
Oliver
Brgds
Oliver
