What is this for???
What is this for???
Hi Guys,
Forgive the noob but I am trying to work out what something is for.....
It is:
1 - Cylindrical - rubberised 50mm long, 20mm diameter.
2 - On the right hand side of the bike under the rear sub frame at the point where the passenger peg loops meet the subframe.
3 - Wired up.
OK, I give up. What does it do, and if I don't use it can I cut it off and terminate the cables?
It is:
3 - Wired up.
Re: What is this for???
Photo?
Would it be the clutch bleeder grub screw?
DJ
http://ep.yimg.com/ca/I/yhst-1510226021 ... 3209426825
DJ
Are you talking about the charcoal canister ?
As DJ said, it is for bleeding the clutch, there is a grub screw in the end and is housed in a foam of sorts and zip-tied out of the way. Pull the grub screw and insert a bleeder and you're good to go for changing the clutch fluid.
2004 Roc.
Just to get you headed right: 25.4mm= 1"atown154 wrote:Are you talking about the charcoal canister ?
Just don't touch it, whatever you do!!!
2017 Husqvarna 701
2007 Husqvarna TE250
2004 BMW Rockster
2004 BMW Rockster
Thanks guys,
As always you are spot on the money!
As advised I won't remove it.
Sol.
Sol.
That is the "time delay trigger" for the clutch spline self-destruct mechanism. It is a top secret install done by Venusian Martians.
I thought they removed that on a safety recall.towerworker wrote:That is the "time delay trigger" for the clutch spline self-destruct mechanism. It is a top secret install done by Venusian Martians.
