Some of you were kind enough to read and comment the post I recently made under the heading of "Cee Bailey Screen"
Following your advice that it could not be the screen causing the problem I booked the bike in at Alan Jeffries they checked the steering damper which appeared to be ok and concluded that the bearings were at fault. These have now been reset and all is well.
Thanks for your help.
Low speed weave
