Rockster forks
Rockster forks
Are the forks [outer slider] of a Rockster round ? The Roadster's are not. Also it looks like there is a fork brace on the Rockster that the std Roadster does not have ? will it fit a Roadster ?
Re: Rockster forks
Rockster forks are from the R1100S, not the standard roadster.
Re: Rockster forks
trickytree wrote:Rockster forks are from the R1100S, not the standard roadster.
Thanks,...I did some checking & see now that they are different. I have a set of Luma-Link fork mounts for aux lights, but the are for round forks, and again the Roadster forks are not round. I'd luv to see a pic of some mounted but haven't found any. Even in the luma-link adds . I contacted them and the guy said he would post a pic of a pair, and give me a price,etc...that was over a year ago ? Still nothing
Re: Rockster forks
And the dash, revcounter (and feed) and speedo (but not the feed IIRC), but not the shock (shared with R850R oddly, as is the rear IIRC).kirby wrote:Gosh!! The front forks on a rockster are off a 1100s
Re: Rockster forks
Rear wheel as well.....5.5" with a 180 tyre, roadster has a 5" and 170
