Finally found a set of side luggage rails for the bike. Used, on FB of all places. Unless I come across a great deal on some used hard cases, I'll continue to use the Cortech soft bags that came with the bike. While they don't hold a lot, they hold enough for my needs.
But my quest for the side rails was really step 1 to allow me to add a top case. There doesn't seem to be a whole lot of options that I've found short of maybe the Givi bracket and a Monokey case which is fine as I had one on my previous R's and it worked OK. Before I pull the trigger though I was just wondering for you guys that are using a top case if you have any opinions of know of better options than the Givi?
As always, appreciate any input-
Top Case
