If I can do it...anybody can
I have over 18,000 miles on my 04 R that I bought new. Up until now, I've had BMW do all the work on it which has cost me $1,347 in labor charges alone - that's in only 13 months. Needless to say, that was incentive enough for me to start doing my own work.
I just finished the 18,000 mile service (except for the abs brake bleed - which I left for BMW to do). With the help of members on this board and other BMW boards, I had all the info I needed and it was both fun and informative. My bike runs great! I even replaced both tires on my own, taking the old ones off and mounting and balancing the new ones. (That alone saved me over $200.)
So for those of you who are thinking about servicing your own bike, I say go for it. If I can do it, anybody can.
I have done two sets of tires, as well as my 12k service.
The 12k service took me about 7 hours over 3 nights. I was overly cautious and had never done the valves and TB balance before.
The tires took me about 4 hours the first time. Well under 2 hours the second time. My last puncture on the rear took 45 minutes to do, including removal of the wheel, mount/balance and installing the wheel.
Tire changing
I would be interested to know how you changed your own tires (and balance) I have seen something some months ago on the same but would like to hear how you did it.
03r
03r
It took me close to 6 hours I'd guess but I know it can be done in much less time. Like Bill, I took it nice and slow, especially the valve adjustments and TB synch since I've never tackled those before.bimrluvr wrote:I'd be interested to know how long it took you?
Changing both tires also took a bit of time - maybe 4 hours? I did one tire at a time since I don't have an easy way of supporting a wheel-less bike. It was also my first time so again I took it nice and slow. I will admit to sweating and struggling to get the rubber over the rims on my first attempt but it was mostly due to my inexperience. It will go much easier the next time now that I know what to expect.towerworker wrote:I would be interested to know how you changed your own tires (and balance) I have seen something some months ago on the same but would like to hear how you did it.
I pretty much followed the detailed instructions in this link :
http://www.clarity.net/~adam/tire-changing.html
The bead breaker and tire levers were purchased from :
http://www.tireqwik.com/tireqwik/breaker.html
And the wheel balancer from :
http://www.marcparnes.com/BMW_Motorcycl ... lancer.htm
Photo of the tire changing platform I made from 2X6 inch wood. (The bead breaker, tire irons and homemade plastic rim protectors are also in the photo.)
Re: If I can do it...anybody can
taosportstaosports wrote:I have over 18,000 miles on my 04 R that I bought new. Up until now, I've had BMW do all the work on it which has cost me $1,347 in labor charges alone
I would like to know the breakdown of those charges. I am looking to buy a BMW bike and it's freaking me out to know that the charges after just 18,000 miles can be that much.
My cars are not costing me that much to maintain.
Here is a breakdown (parts/labor):jbim wrote: I would like to know the breakdown of those charges. I am looking to buy a BMW bike and it's freaking me out to know that the charges after just 18,000 miles can be that much.
600 mile - $38 / $251.
6,000 mile - $19. / $441.
12,000 mile - $108. / $334.
Tires : Metzler Z-6 - $284. / $118.
ABS brake bleed - $16. / $203.
18,000 mile - $27.
Note the 6,000 mile service : $19 in parts and $441 in labor
My BMW shop is in the San Francisco bay area where the cost of living is extremely high. I imagine that is reflected in the labor rates. I'm sure if I shopped around, I'd find better rates (there are 6 within a 90 minute drive from my house). If you are planning to buy a bike, ask the dealer for a similar breakdown of charges. Get it in writing. If they won't do that, simply shop elsewhere.
I will admit, that it has been nice to have someone else do the service while I go do other things with my time. But there's a great sense of satisfaction and pride knowing that I can do it and do it well and I really don't mind spending a day getting to know my bike better.
- Arbreacames
Nice job! I share with you the satisfaction of doing the job myself and saving lots of $$ in the process. I can foresee that tou will not be having the ABS bled for you many more times. If I can do it (see picture), you can do it too. All it really takes is that funnel thingie, and some brake pad spacers. The funnel is used to supplement the tiny reservoir on the servopump during the bleed process. You will get the info on making your bleed tools here: http://users.rcn.com/dehager/service/ab ... dapter.pdftaosports wrote:...except for the abs brake bleed - which I left for BMW to do.
and the bleed process is explained here: http://users.rcn.com/dehager/service/service_abs3.pdf
I bought my R used 11,000 miles ago and it has never seen a professional mechanic since I brought it home.
And here is a picture of the tool I use the most:
Carlos D.
I paid about the same for the 600mi, but did the 6000mi myself. First time doing valves, so I was a bit paranoid about getting it right, but the TBS was easy. The whole job was probably 3hrs...taosports wrote:Here is a breakdown (parts/labor):jbim wrote: I would like to know the breakdown of those charges. I am looking to buy a BMW bike and it's freaking me out to know that the charges after just 18,000 miles can be that much.
18,000 mile - $27.
Got almost 9000mi on the OE PilotRoads, so I'm due soon for a tire change. That I will do myself also...
I think I will bring my bike to the Dealer at around 12000mi and have them do an AnnualService along with a 12k, minus everything I can do (valves/TBS, fluids, plugs). I'll probably do this once, then do everything myself.
My 'stategy' is to bring it into them periodically just to let them know I'm still around & drop a few bucks their way, but I definitely plan on doing the standard maintanence myself.
j magda
TripleLifer Member 454
Deep in the OH wasteland...
DIY maintenance
taosports,
Thanks for the inspiration. After contributing my fair share to local dealers during regular service intervals, am now determined to follow your lead with own maintenance work. All the more reason to adjust our current Beemer inventory so the Mrs. and I can work on (nearly) identical bikes, assembly line style.
Hence, I'm purchasing a 2nd R1150R to match my faithful '02 Roadster... the Mrs. will inherit "Rocket '02", and I'm buying myself a 2004. We'll be doing His & Hers valves, fluids changes, and throttle syncs as part of Date Night activities!
Which maint. jobs do y'all feel are worth paying money for? Some folks do ALL their own work, while others choose to let trained technicians do some of the trickier stuff (or all of it, as the case may be).
Oregon
'96 R850R
'01 R1100R
'02 R1150R
'04 R1150R... soon to be!
(oh, and I can't forget the Buell!)
Oregon
'96 R850R
'01 R1100R
'02 R1150R
