CycleRob wrote:Beemeridian,
I'm sure you did it correctly, but the wire pull to test procedure needs more details.
The primary coil on the single and dual sparks fires both sparkplugs at the same time, ~every TDC of both pistons. The wasted spark occurs on the end of the exhaust stroke of the next cylinder. The spark travels thru one sparkplug to ground then from ground to the center electrode of the other sparkplug then back to the coil. Yes, one sparkplug fires backwards. If you pull off the secondary plugwire and do NOT ground it good with another sparkplug inserted then the other plug will not fire.
Also, you must never open fire any sparkplug wire - - (sparkplug end ungrounded). Doing so forces the 40,000 Volt energy pulse to jump any internal insulation weaknesses or it's own terminal air gap. Once the path is burned in, the coil is most likely damaged.
WTF???
where on earth did you get that information??
Firstly - the plugs will only fire on the Firing stroke, to fire the
plug on the exhaust stroke would ignite unburnt fuel in the exhaust with the exhaust valve AND inlet valve open (If I remember correctly this is how most 4-stroke engines work - the inlet and exhaust opening overlap) : CATASTROPHIC backfire. you'd quite possibly blow the throttle bodies off. (worst case scenario)
Secondly - you've not got a "backwards"
plug in the bike - the
Spark is generated by creating a huge electrical potential difference (voltage) across the two terminals - one at earth, one connected to the coil. Each
plug has that PD (potential difference) generated seperately. If not - for starters you'd destroy the secondary coils with reverse polarity current, and secondly - if the primary coil dies, then, in the system you describe, the secondary
plug won't fire either - which is NOT the case - it's very possible to run the bike with the primary plugs inactive (due to failed coils). If you tried to run the bike with BOTH right side plugs not firing the bike simply wouldn't run.
I agree that it's possible to burn out a coil by "blank" firing it - but you'd have to run it for sometime to manage that I would have thought.
