Eye bolt fasteners
Johan_SA
Eye bolt fasteners
Post by Johan_SA »
Hi All
The wife and I are going on leave in a couple of weeks and I want to tow the R behind the car and use it for our day rides.
I was thinking of using these 8mm eye bolts in the front to strap the bike down. Any suggestions/comments?
Can you see the wonder of the fairy tale?
Suzuki T500J
BMW R1150R
darth_rockster
Post by darth_rockster »
Dude Trailers are for boats! :P
Just kidding I read that somewhere heh heh.
I don't really like the idea of anything extra bolted to the aluminum.
I did find this document in the past that might be interesting to you:
http://www.ascycles.com/pdf/Tiedown2.pdf
I was thinking if i had a trailer i would try to mount this stand that i was using for a short time before i got my center stand. It does have some holes for tiedowns too.
http://www.powerstands.com/acb/showprod ... 10&CatID=1
2004 BMW R1150R Rockster - Edition 80 - #110
RUSOR80!
DJ Downunder
Post by DJ Downunder »
I'm no expert about this but I'm sot sure that I would trust those eye bolts.
Why not tie it down by the bars like most do.
btw...I once rode my bike to a trailer show.. :D .. http://members.optusnet.com.au/~djp1/mypic3130.JPG
awagnon
Post by awagnon »
[quote=
[/quote]
I've seen this reference a number of times. I've tried to figure out how to tie down my 1150R at the fork without damaging brake lines, and haven't had any luck. I've seen pictures of the official BMW shipping instructions. They aren't clear, but it looks like the tie down straps attach somewhere near the upper front shock springs.
I've also been afraid to tie the R-bike down with the handle bars. Again, lots of cables and hoses that can get damaged. Also, the bars don't seem to be all that substantial.
I'm open to suggestions.
Al
Ogden, Utah
2002 R1150RT
2004 R1150R (sold) (sigh...)
2004 R 1150GS
maduko
Donating Member #: 735
Post by maduko »
I would hook to the handlebars before I used those eye bolts. If the straps don't clear the bike use a Canyon Dancer.
I always looped tiedown extensions around the forks of the GS- then hooked the tiedowns to those. But the front fender on the R makes it a little trickier. Maybe remove the fender?
awagnon
Post by awagnon »
maduko wrote:the tiedowns to those. But the front fender on the R makes it a little trickier. Maybe remove the fender?
I have thought about removing the fender to trailer the bike, but it seems a little excessive. Surely the bike isn't shipped from Germany with the front fender removed. If you look at the attached shipping photo, the fender is attached and the straps hook high on the frame, somewhere.
Al
Ogden, Utah
2002 R1150RT
2004 R 1150GS
hirschg
Post by hirschg »
When I purchased my 03 R last October from an owner in Cincinati I tied it down in the back of my pickup to bring it home to Pittsburgh just like it shows in these instructions and it worked great the bike never moved this method allows the front end to act normally like if it was on the rode and as it explains you need to tie the bike down this way due to the telelever front suspension...........Jerry
BLK 03 R1150R
ProductUser
Post by ProductUser »
Check out: http://bmwsporttouring.com/ubbthreads/p ... trailering
This may provide the information you need.
ProductUser
