Where in hell do you mount a GPS?
R1150R with "touring shield" does not offer a lot of space, compared to the old Suzicruiser with a Memphis Fats.
Garmin Quest, but the way...
Ray Barkalow
2004 R1150R
2004 R1150R
I have the touring shield and have a Street Pilot mounted on a RAM mount dead center of the handlebars. It's on a 6" extension so I can move it around to keep a clear view of my instruments. I can change the extension to a 9" and have mounted a still and movie camera. I have to lean it to the side of the shield because of distorsion thru the shield.
Oops.... Good pickup, Arbee. Actually, the bike's analog clock is amazingly accurate. I have removed the "Motofiz" thermometer/clock. I didn't need another clock and the thermometer turned out to be very inaccurate in this location. ( There was another thread about thermometers reading high when mounted near the tach for some reason. I think they get heat rising up from the engine or oil coolers. )Arbee wrote:Al
One clock is slow or one clock is fast....
Al
Ogden, Utah
2002 R1150RT
2004 R1150R (sold) (sigh...)
2004 R 1150GS
Ogden, Utah
2002 R1150RT
2004 R 1150GS
Boris Badenov
Re: Where in hell do you mount a GPS?
Thats what i have.raybark wrote:R1150R with "touring shield" does not offer a lot of space, compared to the old Suzicruiser with a Memphis Fats.
Should work with Quest too, and not going to interfere with any windshield.
"This plan was fool proof, yes! Idiot proof, no!"
I have the BMW touring screen and also a Garmin Zumo 550. I used the RAM mount that came with the Zumo and it works great. I have it clamped to the left side of the handlebar clamp. My view of the odometer is obstructed, but I can see the speedo and the odometer. The arm is just the right length.
I don't have a great picture.
Bob
2002 Atlanta Blue
Lifetime Member #74
2002 Atlanta Blue
Lifetime Member #74
I use a mount that clamps on to my handlebar so that it is easy to remove. (I rarely use my gps except for extended trips.)
Anyway, it's clean and simple and very adjustable as you can see in the 2nd photo where I've pulled it away from the handlebars.
Techmounts like RAM mounts come in all types, shapes and sizes.
http://www.techmounts.com/products/
- darth_rockster
hey toasports,
Nice pics I've been thinking of ordering some ztechnik mounts from there.
Have you noticed any drawbacks with your mount? like does it need constant retorquing to keep the bar in place? or maybe it will fall down and hit the tank?
Also wondering Does that mount fit in between the clamps?
I've been thinking of ordering these parts here for my gps...
2004 BMW R1150R Rockster - Edition 80 - #110
RUSOR80!
RUSOR80!
I've had no problems at all with it. You can adjust the tension/friction so that the device stays put in whatever angle you want. The tension is adjustable with hex keys that they supply. I've never had to readjust them in the 6 months I've been using it.darth_rockster wrote: Have you noticed any drawbacks with your mount? like does it need constant retorquing to keep the bar in place? or maybe it will fall down and hit the tank?
As far as placing it between the clamps, I wanted to but if you look between the clamps (at least on a R1150R) you'll see that there is less clearance inside than out.
EYE'S ON THE ROAD PEOPLE!!! Half the fun of touring on the bike is not knowing exactly where you are.I have logged 100s of thousands of miles without a gps. All over Canada and the states and always made it where I was going. Why would you want more distractions?
My $.02
My $.02
Keep Your Stick On the Ice.
Listen to Me at kaxe.org
rbertalotto
I would mount it next to the oil temperature gauge, above the radar detector and to the left of the CB radio, do remember that to the right you'll have to move slightly the clock/ambient temperature readout and the sirrius radio. You can attach your cell phone to the GPS with double backing tape.
Now, regarding your weather channel I really don't know where there is room for it......
Ahhhh.....don't forget to bring an additional alternator belt, for the second alternator that you had to install to drive all the above.
Don't be mad....it's just a bit of Sunday levity.......
I use a Ram mount for my Garmin Nuvi. I made a spacer and adapted the dash mount so I could bolt it to the Ram mount. The Ram version was too loose to trust on the bike. I stick an elastic band around the lot for security.
Bought an Aquabox from RAM as well but it was too small for the gps :-( Anyone want an aquabox?
