Spark plug coil extractor don't work...
chasestudio
Post by chasestudio »
Evening all.
Lined myself up to perform my first solo service this weekend - 18000 miler. Got myslef a workshop manual, browsed this august forum, acquired the accumulated wisdom of members past and present (thanks guys/girls), bought two sets of feeler gauges, an Optimax, service kit and Twinmax, and still had change from what I expected my local dealer to extract from me - a good start.
Removed cylinder head guards and coil covers, selected coil extractor from my (mostly complete) toolkit, placed it over the coil and pulled. It came off. Repeat. Same result.
Must be the wriong tool, I surmised, I needed oil anyway so off I went to BMW dealer and acquired the 'right' tool. Returned and found that new tool is too small (I know, I should have taken the old one to compare).
So, I have one tool that fits, perfectly, but pulls off at the least effort, and another that doesn't fit. To make matters worse my maintenance manual referes to yet another tool (12 3 520). What's a feller to do?
I CAN bodge it and apply long-nosed pliers, but I don't want to; this has become a matter of honour.
Has anyone had a similar experience? If so, how did you resolve it?
Biff's R
Donating Member #: 289
Post by Biff's R »
If you have a 2 spark engine, it can be tough. the puller that comes in the tool kit is marginal at best. I got one that is aluminum from my dealer for about $30(way overpriced). It is a 100% improvement.
Jeff (lifer #289)
'17 F800GSA
'04 R1150R
Beemeridian
Donating Member #: 477
Post by Beemeridian »
88
snowprick
Donating Member #: 3953
Post by snowprick »
I have not tried this item but it may solve your problem.
http://www.marcparnes.com/BMW_Plug_Tool.htm
Ves
Post by Ves »
I've never used a tool. I pivot the coil as far as it will move toward the wire side (down on the right, up on the left?). That gives me enough room to get the forefinger of one hand just under the coil where the wire comes out (no you can't get your whole finger under there but you can get enough). I grab the front of the coil with the thumb and forefinger of the other hand. And, pull. Comes right out. If it doesn't come right out, just jiggle a little while pulling. Just make sure you're pulling on the coil, NOT the wire.
Hawk
Post by Hawk »
Concur on the Mark Parnes tool. Also, when you do get it off, a dab of dielectric grease (NAPA) before reinstalling will make it easier next time. :D
Life Member #554
2004 R1150R
86 Honda Nighthawk 700S
Kawasaki Z1
Morgan and Thoroughbred
chris
Post by chris »
I modded the tool by adding a bit of plastic between the legs to make it grip. Works fine now.
Pic in this link.
http://r1150r.org/board/viewtopic.php?p ... ght=#91528
Chris
2011 G650GS
Photos
chasestudio
Thanks Guys,
Much useful advice, I'll press on.
