Hello,
I'm wondering if anyone who has had their dealer install Verholen Bar backs on the R1200R can comment on what sounds like excessive cost estimate I was quoted for dealer to install. They quoted me $146 USD to install the Verholens because of needing to re-route cables, not new, longer cables, just rerouting. I really just want to do this myself, but it doesn't sound as simple as just lifting bars, inserting verholens and retorquing. So I prefer dealer to do. I appreciate any input from others who have had dealer do this or done themselves. I saw some information from doing Search on the topic, but looking for additional input.
Thanks,
I also thought as long as the bar backs dont require longer cables, the dealer should be able to charge less if they do this along with work on the NHTSA brake recall.
Verholen Bar backs question - dealer cost to install
BackNBlack
Re: Verholen Bar backs question - dealer cost to install
Hi Bill
If you don't want longer cables (--> brake line) it is easy as 1-2-3 and will take you or your dealer about 10 minutes of work.
You have to be careful then not to tilt the bar back too much so that the brake line is not stretched too much.
Better get a new (about 1.5") longer brake line. Then you can play with the handlebar as much as you like.
Cheers
qgaex
+withthatcoollaidbackbarposition+
Cheers
qgaex
It's very easy to do, why not put a big fluffy towel on your tank and take out the 4 bolts holding down the bars?
Then you can hand-tighten everything and see if it all works. With the bike on the centerstand you can also unload the front and check for stretching of cables etc. in lock to lock movement. If all works, tighten it down and forget about it. If there's an issue you'll see where and either have the dealer do it, or buy the longer brake line. Either way you'll see where the issue is and don't have to rely on what they tell you may or may not need to be done. Since in my case it didn't take longer than 20-30 minutes, $140some seems excessive.
In my case I did not need to change the brake lines or reroute them.
For me it was as easy as lifting the bars, installing the Verholens and torquing everything back down.
8,000 miles later still have not experienced a problem.
Oliver
2008 R1200GS
2008 R1200GS
Just one word of warning: On mine, it seemed that the handlebar bolts were torqued down by an uncalibrated gorilla. The wrench I started to use to remove them was slightly worn, and it almost stripped out one of the bolt heads. So be sure you're using a good wrench and that it's fully engaged with the head.
BackNBlack
Thanks for input on this - I appreciate! I have done handlebar swaps before on other bikes, so shouldnt be hard to pop on the Verholens, and then if I've got any question, I can have service check it when I'm in for my upcoming 6K.
Thanks again,
Thanks again,
R1200R!
I'd find another dealer if they wanted a buck-fiddy to install a pair of bar risers.
It'll be a bit easier if you have a friend hold the bars while you install the risers. That way you'll be able to keep the front brake and clutch reserviors level.
15-20 minutes, tops.. go for it.
famousperson
- Sextuple Lifer
Took me ten--without a friend...NCGS wrote:I'd find another dealer if they wanted a buck-fiddy to install a pair of bar risers.
'07 R1200R
Life Member #599
NAUI Inst. #1434 (since 1969)
Life Member #599
BackNBlack
Yeah, and now that they quoted me $390 for the 6K service, I'll probably need to get the manual and some more tools. Insane - not what its worth, what they think they can get away charging me.
R1200R!
