Help identifying a bolt...
frbank6
Post by frbank6 »
On the right hand side of the engine, at the bottom front, is a 10mm bolt. Does anyone know what it is? Mine has weeped a small amount of oil some time in the past. I don't see any mention of it in the Clymers manual.
2003 R1150R ABS Dakar Yellow/Ferro
Veritas vos Liberabit
Byrdguy
Re: Help identifying a bolt...
Post by Byrdguy »
If you're talking about the large 10mm allen head plug, I think it's a plug for the oil pressure relief piston. (anyone know for sure?) In any case there is a sealing ring/gasket behind it that may need replacing. Mine gets gunk around it also, but not enough to pull it out, I just clean it off now and then. You could try tightening it, but I would check the torque spec first.
