How to Reset Motronic
webmost
Post by webmost »
The Motronic on my 2003 R1200CLC can be reset to defaults and put in learning mode by turning on the ignition without starting, then turning the throttle grip all the way back and releasing three times, then turning off the ignition.
Is there a similar procedure for the R1100R?
2003 R1200CLC "Annie"
1995 R1100R "Acela"
2006 Honda 919 "Busted"
philbytx
Post by philbytx »
Yup!
Pull main fuse to Motronic. Let it sit for a minute, then replace fuse, turn ignition on and do the WFO to idle throttle reset twice. Then you are done
Phil C.
2003 R1150RT "DaRTh"
2000 R1100R "LeRoy
webmost
Re: How to Reset Motronic
Post by webmost »
Will consult my Haynes for the main fuse, or disconnect battery.
1995 R1100R "Acela"
