For my job I sometimes have to carry a set of blueprints. My problem is when I cannot fit them in my saddlebags. I was just curious if anyone has ever bought or made a tube to carry prints and how you attached them. I was figuring I could make some sort of strap system attached to my saddlebags or luggage rack but wanted to see if anyone has done anything like this before. Thanks in advance.
Kevin
02 1150r
Just Curious
Re: Just Curious
I used a FedEx tube strapped across the back seat just the other day. Works great, it's free and it's re-usable. If I had to do this on a regular basis and needed something watertight I would use a PVC tube (3 inch or so) with a couple endcaps, only one glued on. The same setup works well for fishing rods.
Re: Just Curious
I appreciate the info. I was thinking the pvc would probably be the best option. I would like to find a way to permanantly mount it without it looking completely ridiculous.
Thanks for the info
Kevin
Thanks for the info
Kevin
Re: Just Curious
My daughter is an art student, and we got her a plastic tube with screw on ends to transport large artworks (on paper). The cool bit is, it already has a strap attached so you could sling it over your shoulder.
http://www.plazaart.com/products.php?pa ... &id=450255
P
P
ATGATT: Because it's better to walk away in disgust than ride away in an ambulance.
