Centech install
stevedore
Centech install
Post by stevedore »
I recently got a Centech fuse box and relay. I don't want to drill a bunch of holes in the bike to mount it. I saw a pic of a bracket that sits on top of the air cleaner and uses existing screw to mount. I like the idea. Is the bracket for sale or does one have to construct one themselves? I'm sure this topic has been covered but i can't find the thread, sorry.
careful what you ask for
Twempie
Re: Centech install
Post by Twempie »
I have a Centech on order. When it arrives, FWIW, I intend to use a wide strip of velcro to hold it in place.
2003 R1150R Single Spark Non-ABS
Railbender
Donating Member #: 689
Re: Centech install
Post by Railbender »
The airbox mount is from CycleNutz;
http://www.cyclenutz.com/products/elect ... unt_2.html
I just got mine the other day. I have a Blue Sea fuse block and on my R1100R the seat will not go on in the low position. :cry: I had to trim the front of the seat pan to get it to go in the middle position. I am going to remove the tank so I can see exactly what the problem is. I think the Centech is smaller than the Blue Sea so you may not have a problem.
Airman
Re: Centech install
Post by Airman »
Railbender wrote:The airbox mount is from CycleNutz;
Is this a water tight enclosure ? The only real failing of the Centech unit is that it's completely open. I think the Centechs are somewhat smaller than the Blue Sea. The usual Centech mount on the RR is to make a little plate to bolt to those screws where the diognostic plug used to be, or perhaps like Twempie suggested, a strip of velcro.
Railbender
Re: Centech install
Airman wrote: Is this a water tight enclosure ? The only real failing of the Centech unit is that it's completely open. I think the Centechs are somewhat smaller than the Blue Sea. The usual Centech mount on the RR is to make a little plate to bolt to those screws where the diognostic plug used to be, or perhaps like Twempie suggested, a strip of velcro.
It is not water tight. The cover on the Blue Sea has cut-outs for the wiring so the only real protection is from the seat. If water becomes a problem some closed cell foam strips in the cover cut-outs might help.
taosports
Re: Centech install
Post by taosports »
Here's what I did a number of years ago, and it works fine w/o having to drill any holes on the bike.
Happy Rider
Re: Centech install
Post by Happy Rider »
I followed taosports lead and did the same. Works very well for me.
Martin
2004 R1150R ABS - silver
BMW MOA # 139330
digga
Donating Member #: 600
Re: Centech install
Post by digga »
Happy Rider wrote:I followed taosports lead and did the same. Works very well for me.
Martin
+1 here.
much the same.
mate milled me a 'L' brkt. sits right under the tank, (no water problems in 12 mths) but uses the 2 air box screws to fix
Diagnostic plug moved forward to allow above.
