hi.
i am close to custom fitting a pelican case to my r1200r.
i would like to put in some metal plates to sandwich reinforce the plastic bottom of the case.
i need 8 thin (2-5mm) metal/aluminum squares, each about 5cm square with 5 holes predrilled.
does anyone know who i could contract this out to?
thanks.
-daniel.
need.metal.fabricator.recommendation
it seemed like a good idea at the time
Re: need.metal.fabricator.recommendation
Dan,
You might get better responce if you say where you live. It's not a Harley list, we (speak for myself) won't come and steal your bike.
REV 1:
See it now.
REV 1:
See it now.
AmostThere
Since I'm on the west coast I was going to look to the metalworkers that make stainless parts for the marine hardware industry. If you're near a coast that might work for you. Maybe check with Brian Gordy at LumaLink, they might have ideas (they're in Arkansas).
2008 R1200R Granite Gray
That's a very easy fabrication job. All you need is a job shop with a shear and a drill press. There are probably dozens of them between Princeton and Philadelphia. Look in the Yellow Pages or on Google.
Alternatively, assuming you have an electric drill but not a bandsaw, you could buy 2-inch wide 1/8-inch thick aluminum strip from onlinemetals.com. They'll cut the pieces to length for, I believe, 50¢ a cut. Then drill your own holes.
