Fuel Filter replacement
Donating Member #: 312
Re: Fuel Filter replacement
Post by boxermania »
David
Finally a bit of information has surfaced.....your bike is an 04' with the 4 plug engine. I venture to say that one or both of your stick coils are weak....... this is a common problem around the mileage your bike is showing.
Do a search to find how to check them or hopefully someone will chime in, if not send me a PM with your phone and I'll walk you through the procedure.
Good luck
Sunbeemer
Donating Member #: 593
Post by Sunbeemer »
also check the trottle cable nothing appears to loose
If you pull the cable end located over the right-hand throttle body out of the ferrule it rests in and then reseat it, I suspect that will fix the problem.
If after a couple minutes at idle the right hand cylinder head is not as warm as the left, this is very likely the problem.
ADIOS!
garr2
Triple Lifer
Donating Member #: 781
Post by garr2 »
Removing the single use OEM clamps was the biggest pain for me
I had more trouble with the supposedly reusable OEM vent line clamps.
I gave up trying to reuse them when I couldn't reclamp them.
I didn't have any hose clamps in the shed but did have a couple of spare 9 mm EFI clamps.
After installing them onto the vent lines, getting the fuel pump/filter assembly back into the tank and attempting to reposition the fuel plate back onto the tank I found that the extra size of the EFI clamp fouled the edge of the tank cut out so that the bolt holes on the plate and the tank didn't line up.
So I got to practise taking the fuel pump/filter assembly out again, and them went for a drive.
I finally settled on the smallest 8-12 mm hose clamp I could find in an auto parts store.
Overall though the job was doable for a first timer - tedious and at times frustrating - but doable.
It certainly helped having read the filter replacement threads on this forum.
Ric
Post by Ric »
I love my R1200R but......all this trouble to replace a fuel filter !!!
Jezzz.....what will it take to replace something really complicated...like a tail light bulb.
10 R1200R
09 KLX 250sf
74 H2
77 RD
69 Kawasaki Bushwacker
67 Kawasaki 120SS
65 CB 450 Black Bomber !
Ric
Post by Ric »
macx wrote: Other than that, here's how I did it on the outside.
http://www.mediafire.com/?dj2jjdyjlm0
macx.....I couldn't get this link to take me anywhere but to a bunch of ads.
10 R1200R
09 KLX 250sf
74 H2
77 RD
67 Kawasaki 120SS
goomicoo
Post by goomicoo »
Ric wrote:I love my R1200R but......all this trouble to replace a fuel filter !!!
Makes you seriously consider relocating the filter outside the tank :x
Atlantic Blue
2002 R1150R
The bumble bee's gone
davidh8462
Post by davidh8462 »
All is well with fuel filter. I put everything back together okay. It was just the fuel line housing not seating properly. Once I retset it in everything was fine. Thanks to all for the suggestions and advice.
Silver 04 R1150R
