Starter noise
Dr. Strangelove
Starter noise
Post by Dr. Strangelove »
Recently my 68k mile bike's starter occasionally will "whirr" instead of engaging the engine. I let off the starter button immediately, re try and it has always started, except for once, on that next try. No clunky or metallic noises, just a whirring as if the starter is spinning very fast with no resistance.
I have not pulled the starter, but I am thinking that the spring that engages/disengages the shaft may be very dirty, thus hindering travel.
When I pull the starter, I will look at the flywheel's teeth, but post this to see if my thinking is likely correct or if anyone has any other suggestions.
If the teeth on the flywheel are only polished/slightly burred (and not missing) and the shaft now cleaned and the bike still whirrs, I'd guess a new starter is in my future?
Is bearing grease good for the shaft?
tia John
PS Torrey was great
'09 Schwarze Blanche DuBois
chibbert
Donating Member #: 202
Re: Starter noise
Post by chibbert »
Dr. (and Stella)
I would tend to agree that dirt and grime are inhibiting spring travel. I believe any light-weight grease would be fine for the shaft.
Good luck and keep us posted on your findings.
Chris
2004 R1150RS
Donating Member #: 312
Re: Starter noise
Post by boxermania »
Dirt is the problem, the starter gear that is projected forward to meet the flywheel is not doing so. The starter needs to be removed, the shaft where the gear slides on, along with the gear must be cleaned and very ligtly lubricated with Moly grease as excess grease will act as a dirt magnet.
While the starter is out it pays to check the condition of the flywheel teeth, not rounded at the point of engagement or broken or missing, replacing the starter is easy, not so the flywheel.
Break out the instruments and go to work.....if I remember correctly Brian had a pictorial on the whole thing.
Dr. Strangelove
Re: Starter noise
Maybe this weekend I will tackle this. I hope I can find moly grease somewhere
Have to do all lubes also.
what's the top speed on this scoot, btw? :) I mean the real one, not the speedo reading.
chibbert
Re: Starter noise
Post by chibbert »
Top Speed - I think will depend on your weight and flat, uphill, or downhill riding. I had mine at 123 indicated which equated to 116 gps speed a couple of times but I'm a bit rotund. I've had my RS to the same but it feels like I could get more out of the RS if I asked for it.
2004 R1150RS
R1150Rclean
Re: Starter noise
Post by R1150Rclean »
Dr. Strangelove wrote:Thanks
BMW lists top speed as 135 mph, I have had it to 127 mph (odometer) which is 3 mph fast at "30 mph" (based on radar signs), so 124 mph but I was not tucked all the way and it was a shorter run. 130 should be doable.
harveyrawn
Re: Starter noise
Post by harveyrawn »
One other thought. If you haven't done so already, having the flywheel exposed is a chance to do and dirty and dirty check of clutch spline free play.
Harvey
Recharged on an '02
Dr. Strangelove
Re: Starter noise
harveyrawn wrote:One other thought. If you haven't done so already, having the flywheel exposed is a chance to do and dirty and dirty check of clutch spline free play.
Oh, do tell how---tia
Ok, I'll come clean...126 on the gps and I was feeling the rev limiter. Deserted road into Tucumcari (NM 209), arrow srtaight, no traffic except for that rattlesnake, flat, good surface, not particularly tucked. Did not look at speedo for indicated, and saw the 126 when I stopped.
Now, I don't "have" to do that anymore, but I still refuse to grow up.
Stella! is a good girl.
Sunbeemer
Donating Member #: 593
Re: Starter noise
Post by Sunbeemer »
Been to 124 on the clock, don't know what that really is, but there was more left...
I think your starter has accumulated grit and grease on the Bendix shaft preventing the pinion gear from being thrown out to engage the flywheel starter ring gear... kind of like plaque in arteries, just need to get in there and clean it out. I'd suggest a light greasing of the shaft after cleaning, and any multi-purpose grease should work.
ADIOS!
harveyrawn
Re: Starter noise
It's described in a couple of posts in the thread named "Cyclerob - Clutch Spline Greasing?" at viewtopic.php?f=2&t=17859.
Harvey
Recharged on an '02
Boxer
Re: Starter noise
Post by Boxer »
Don't forget to disconnect the battery negative cable before attempting work on the starter. You can do it without disconnecting, but its highly risky behavior.
jm1515
Triple Lifer
Re: Starter noise
Post by jm1515 »
http://advwisdom.hogranch.com/Wisdom/sq ... tarter.pdf
If you haven't done this before the above link will surely be helpful.........
j magda
TripleLifer Member 454
Deep in the OH wasteland...
Re: Starter noise
There is Moly grease and Moly paste, theonly difference is the the first one has 4% Moly, the second 60% Moly. You want the second and Honda has sells it.
Dr. Strangelove
Re: Starter noise
I pulled the starter and cleaned and greased.
FYI, in my case, I had to remove the jump lug in order to remove the cover, no big deal, but it doesn't just pop off with the lug in place.
I did disconnect the battery before hand.
It was very gunky, though the travel was better than I thought. It did tend to catch slightly, though, and that, I hope was my problem.
To Stella!'s innards...
dirty starter
and
and
on the next one see how the leading edge of the gear teeth is beveled for engagement--at least I HOPE they are supposed to look this way.
and after cleaning with Goof Off and windex, brush and terry cloth. Then smeared with the lube shown (not the paste as far as I can tell). I coated anything that looked like it could use it and the operation was very smooth and crisp afterwards.
It should be noted that the pin holding the fulcrum of the lever from the spring falls out easily. It can be lost...that would be bad news.
Connected everything back, and lastly the battery, and she started just fine, but time will tell, I suppose.
BTW, the torx bolt in back of the starter is hard to reach and needed a 3" extension to address it.
Reset the Motronic and I hope I am good to go.
I did do the dirty and dirty test of the clutch for free play and I could not get anything to move, even slightly, and I tried all sorts of ways. The teeth on the flywheel looked good also. So, I guess Stella! falls in the 95+%...woo hoo
Re: Starter noise
It appears you didn't remove the components for cleaning, another way to accomplish the same is to use brake cleaner and spray on the assembly. Nevertheless, I think you did a fine job.
Boxer
Re: Starter noise
Post by Boxer »
I'm happy to see you properly anesthetized Stella prior to the surgery....else there could have been shocking repercussions. :biggrin:
Dr. Strangelove
Re: Starter noise
boxermania wrote:John
Al, when the pin came out of the lever the copper cylinder within the spring extended out a lot, almost completely, as can be seen in the third picture. But no, I didn't break it down anymore than what can be seen. I did operate the mechanism on the starter proper as I cleaned it.
And, Boxer, anesthesia is a very good thing
Dr. Strangelove
Re: Starter noise
follow up
It was real cold here last weekend and I rode Stella! for the first time in a month. On almost all starts I got the whirring sound. Cold? Not cleaned enough? Lube instead of paste?
Went to Honda and got the paste (8.95) and will take it apart again today and this time open the component parts. Need to get some brake cleaner to really clean things and see what happens
a new starter may be in my future? or a rebuild?
will report
Dr. Strangelove
Re: Starter noise
Took it apart and it was still pretty clean in there and didn't really feel any binding, but it looked like the moly lube 4% had dissipated somewhat.
this time took apart the bendix spring "plunger." Looked a bit dry in there. Also, most surfaces showed some etching, sl, from oxidation.
Cleaned every surface well and then polished them with Flitz and a dremel. Things were really smooth and shiny. I polished the spring some because I could see where it rubbed on the copper cylinder. I also stretched it slightly to give it, well, more spring.
Then everything got a thin coat of the moly paste and reassembled.
Kind of chilly and wet here today, but she did start right up. Time will tell. If the starter acts up again I guess it will be time for a new one after 70k miles.
Re: Starter noise
Post by CycleRob »
Dr. Strangelove,
That solenoid plunger spring disengages the gears when you let go of the starter button. Stretching it makes it (slightly more) resist the pinion drive gear engagement force when you hit the starter button.
It was a long time ago when I took GoldBoxer's starter off to clean-n-grease the Bendix mechanism. Trying to remove the bendix from the shaft required a force more than I feared would destroy the powder metal wire ring retainer. Did not have the puller needed. Not to worry, a good cleaning/greasing is possible without taking it apart. I remember spraying it with spray brake or carb clean, working it back-n-forth, then blowing out the soiled solvent with a blowgun, and doing it again. Next I smeared the shaft and worked in the Moly grease. It moved smooth as glass. After reassembly, hitting the starter button generated the quietest/quickest gear engagement I had ever heard. That smoother, quieter gear engagement sound lasted for months.
