Hello all,
I normally like to warm up to a forum before asking for help, but I am at a loss on my problem and need help. Sorry the first post is a cry for help. (sign of weakness I know)
I have a 2000 retired police R1100RT. No hack job on the "demilitarization" just the external lighting and radio removed. The problem came on suddenly and I have been looking for the ghosts without luck.
Problem is as follows:
1. Right rear turn signal not working (bulbs changed with known working ones). Fast flash as indicating missing bulb to rear.
2. Left Front and rear signals working, but rear running light/license plate light and right front signal also blinks at same rate as turn signal? Crossed wire?
3. When the headlights are on the left front and rear turn signals come on brightly such as when indicating a turn but with steady burn. They have a weak flash when indicator is pressed.
I have chased the faulty grounds and such and I am now pulling out much of the wiring left over from the emergency equipment such as the strobe head unit and wires. Putting in the dual seat conversion, but am at a loss for this electrical issue.
Anyone had a similar problem and could point me in the right direction. I did and search but didn't see this listed. Sorry if this has been gone over, just point me in the right direction.
Thanks,
Pete
R1100RT-p turn signals gone crazy
thevalentines2
Re: R1100RT-p turn signals gone crazy
I just got a 01 RTP and when the r fr turn signal stopped working, this is what I did.
I popped both mirrors off and the cops added a relay that flashes both turn signals at once.
So i took off the relay inside mirror and hooked up oem turn signal lite wires on both sides and it works perfect.
One lite was still intermitent , the bulb was loosing in the socket, I pulled the base connection for the bulb up{it was pushed way in} and all is good now.
Let's stay connected because I am converting my RTP to a 2 seater and need advise also on dumping radio box, hooking up rear seat.
I did just mount some PIAAs to the fr crash bars and they look great.
